![]() ![]() ![]() Drives: 07 Yaris HB Join Date: Apr 2007
how can u test a sub? URGENT
URGENT.....how can u test a sub without installing it into your car? URGENT
Rice on, Rice Off Ron Cabading |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
not sure how but seen it done with a multimeter....
![]() ![]() Drives: 07 Yaris Hatch 5speed Join Date: Nov 2006
Not really recommended, but you can hook it up directly to the wall AC plug, it'll give a 60hz sound.
Or, you can hook it up to any home or car stereo, just don't play it loud. |
Chode
Drives: Silver 5 Door YRX 1.5L I4 Join Date: Feb 2007
search for SSS base test (silicon sound system) is a sound file you play over the sub, tests the range of the sub from 360 hertz to 10 hertz.
#5 | |
"URGENT.....how can u test a sub without installing it into your car?" |
Look mum no stars!!
go ring your local audio dealer.......dont spend time waiting for a reply here....most people might know or dont know......better to ring someone locally and get a straight up answer
Chode
there is no way to test it without hooking it up
#8 | |
![]() ![]() Drives: '08 Polar White 3dr Join Date: Jun 2007
If so then just grab a new 9v battery and connect it to the speaker terminals. If it jumps "in" then you hooked up your + and - backwards. Hook it up correctly. If the speaker jumps "out" to the full travel of the speaker then it's not blown. If it doesn't move or barely moves then it's blown. |
actually, you said "without installing it in your car", NOT "without hooking it up". I think most people read what was being asked.
Ask a specific question, give some background maybe? and you'll get great answers on here.
![]() ![]() ![]() Drives: 07 Join Date: May 2007
Connect an ohmeter to it. Put the meter on Ohms, it should read the voice coil resistance (2, 4, or 8 Ohms typically) If it reads a short across the plus and neg of the speaker, its SHOT.
El Huevo
Drives: 2007 Liftback Join Date: Aug 2006
ask it a simple question like "what is 2+2?" if it answers correctly, it is fine! and if it does not answer, then it probably does not work...
JUST INSTALL THE SPEAKER, IF YOU HEAR SOUND, BINGO! IF NOT THEN TAKE IT TO A PROFESSIONAL STEREO SHOP.
| Test Car needed for BlueBat overlays | Turbo&Auto | General Yaris / Vitz Discussion | 12 | 07-24-2009 03:35 AM |
| I test drove a Yaris, Versa and FIT | CanadaCraig | New YARIS Purchase Forum | 41 | 11-29-2008 10:18 PM |
| I finally test drove a Yaris Hatch... | ECHOKnight2000 | New YARIS Purchase Forum | 10 | 02-01-2007 01:18 PM |
| Seeking Hatchback owners to help with parts test | why_14 | General Yaris / Vitz Discussion | 2 | 12-06-2006 12:16 AM |
