Old 07-07-2007, 09:02 AM   #1
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Originally Posted by reznunt View Post
I'm running 40 offset on 15" wheels and 205-50's on about a 2.5" drop and I get light rubbing under severe driving conditions. for a 16" or 17" wheel, i would suggest an even milder offset, closer to mid-40's depending on the tire profile.
have you thought about adding camber bolts, someone was talking about doing this and I think it may work since them rubbing is on the outer, I actually think visually neg. camber looks cool, I'm still doing some research
SPONSORED BY
Old 07-09-2007, 02:23 PM   #2
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
since it's not a track car, the really minor rubbing on the splash guards isn't a problem for me. i've had this type of rubbing, and alot worse, in many different cars so i'm used to it. if i wanted to put her on the track, i'd raise up the height and/or remove the splash guards anyway. i'd have to say no to the camber bolts to try and save as much tire as i can. but they would definitely work for you.
reznunt is offline   Reply With Quote
Old 07-09-2007, 02:26 PM   #3
brickhardmeat
Lonesome Cowboy
no camber bolts for me either now that I have the basics installed , I'm not concerned with rubbing
SPONSORED BY
How to determine proper wheel offset? Yaris Revenge Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 05-23-2009 10:41 AM
Yeah, I know... I'm a sellout. ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 53 06-21-2007 12:29 PM
Carbon offsetting with TerraPass BailOut General Yaris / Vitz Discussion 14 05-28-2007 12:29 AM
Offsets? Yarisagos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-12-2007 08:06 AM
Wheel Offsets bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-08-2007 01:55 AM
