Old 07-11-2007, 01:46 PM   #1
dallas
Drives: Yaris Hatch /Landrover D2
Removing weight helps acceleration as it takes less energy to move the mass but beware of diameter too. If you go with a 17 wheel even if its lighter than the stock steel wheel (not many wheels like that) you have moved the mass 3inches further out from the hub (based on 14 wheels) so it will take more enery to turn the wheel. I have 205 50 15 tires on light weight 11lb wheels , the stock steel wheel and tire are still lighter.
dallas is offline   Reply With Quote
Old 07-11-2007, 01:58 PM   #2
CaysE
That Focus Guy
CaysE's Avatar
Drives: 2004 Focus RSVT
This is not necessarily true, because you're not taking the tires into account. Tires can typically weigh between 15 and 20 lbs, and if you maintain the overall diameter of the wheel/tire combo, a lighter weight wheel with a larger diameter would require a tire with a shorter sidewall, thus a lighter tire. Depending on the actual weights and wheel design, the mass can even be moved inward.
CaysE is offline   Reply With Quote
Old 07-12-2007, 03:07 PM   #3
dallas
I did consider the tires in my weight, and yes the shorter sidewall helps, but the mass of a wheels weight is not in the spokes so if you move it 3" further from the hub even thought the tire tread is the same diameter away as the 14wheel, you have added more mass further from the hub over a stock 14" wheel. I have yet to find a 17" wheel tire combo that I can afford that would weight less than the stock 14 wheel and tire combo.
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
Do bigger wheels and tires improve performance Driver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 10-14-2006 06:01 PM
Enkei RZ5 wheels on Liftback kennywhy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-23-2006 04:22 AM
