![]() Drives: Yaris S Sedan Join Date: Jul 2009
HELP!!!! My clutch is squeaky...
When i shift from first to second it squeaks but when i shift from other gears it is fine... also when i check that it is in nutral it squaks too.... what can it be?? my clutch is responding good so i don't think i need a new one.
What is it???
Gonna live today like it's my last day!!!
The Martian
Its nothing much just a squeak in the shifter. Just go from the shifter to the transmission and find the squeak and put some grease on it.
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker. |
ok cool...
thanx
SRacer
you know what my clutch squeaks too
whenever i press it down, i think i might to put some grease on mine too. anybody recomend any good brands and how exactly do you put it on?
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop." - Dominic, Fast & Furious ![]() Learn The Truth about Six Pack Fast! |
![]() ![]() ![]() Drives: toyota yaris Join Date: Jan 2007
mine does the same but from 2nd to 3rd as well!! better go get some grease ...
I actually had the same problem with what grease and how to do it.... so i figures since i still had like 10,000 miles b4 my warranty was i up i would use it... i took it to the delear and they put the grease on it.... no more squeaky for me.... lol
Thanx for all ur help though
The Martian
Yeah I found the squeak in mine if u look slightly down and to the right of your engine you can see the cables moving and just figure out which one is squeaking. I just use a heavyweight gun oil>.> Redneck I know but it seems to have worked!
cool... i will keep that in mind next time it happens, hopefully it doesn't, cuz i know for a fact i will be out of my warranty by then....
AKA Samurai Racer
i got the same squeak !! LOL , a yaris factory defect? maybe the cable should have been gaurded ?
#10 | |
SRacer
but yeah, i will have to definetly have to check it out!
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
This sounds really similar to a problem I'm starting to experience as well. I just broke the 28,000 mile mark on my yaris. I notice there's squeaking in the lower gears 1st to 2nd, 2nd to 3rd, as WELL as in neutral when moving the stick just left and right. Do you guys think this is the same problem? I'd like to have something to tell my mechanic when I take it in other than that the car makes a sqeaky noise when shifting.
Clutch springs are just squeaking. I just picked up my Yaris literally two days ago. It's got 117 miles on the odometer. Mine started doing it, so I had my roomate look at it. (He's an ASE Certified master mechanic employed as a full time tech at the local Toyota dealership) That's what he came back with. No cause for concern.
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Squeaking clutch pedal
After reading the squeaking transmission thread, I thought I'd post this up.
The clutch on my 2007 liftback squeaks when I depress it and let it out, too. Anyone else have this issue? Any quick fix?
Subcompact Culture: The Small car blog |
#14 |
やりすぎだ~
Squeak at the pedal area or the hydraulic piston area near the transmission? I've never had that problem yet, but on some of my older cars I just used WD-40 for the pedal joints. Not a permanent fix, but does the job for a while.
#15 |
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
I had the same problem, I removed the little rubber boot by the hydraulic piston of the clutch and sprayed some amount of sea foam deep creep and worked great it’s been about 5 months and the noise hasn’t come back.
#16 | |
Yaris = <3
Drives: '08 Sedan - Flint Mica Join Date: Jan 2009
Would you be able to take a picture of what you're talking about in this post? It would be GREATLY appreciated; I'm sure not just by myself. Thanks in advance!
..:'; Nick ;':.. ============================== 2008 Yaris Sedan - Flint Mica ============================== Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter ============================== |
#17 | |
Here is the pic of what I did and took care of the noise, try to use a good lubricant; WD 40 will evaporate too quickly. Let me know if this worked for you guys, good luck getting rid of the squeak |
#18 |
Yaris = <3
This seemed to have worked for me. I used spray white grease from Canadian Tire. It's been raining all yesterday and it was pretty muggy/foggy outside today and no squeaking.
| Manual Yaris performance info? | SimmZ | General Yaris / Vitz Discussion | 22 | 10-27-2009 09:27 AM |
| Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) | gaffo | General Yaris / Vitz Discussion | 28 | 07-15-2007 07:55 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
| The Toyota Authorized Repair Manual. | LoudYar | General Yaris / Vitz Discussion | 3 | 03-29-2007 12:20 AM |
| Finally drove the manual! | drdavidr4u | General Yaris / Vitz Discussion | 2 | 06-14-2006 08:32 PM |
