Old 07-13-2007, 11:34 AM   #1
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
I found some for $99 from that company but other than that not much for now. What I'm getting is 15mm wheel spacers not just 5mm because the rims i'm using are at a +37 offset i believe
Old 07-13-2007, 11:41 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
With a 15mm spacer and a +37mm rim, you'd be running at +22mm.
Well... that's insane on a Yaris unless you've modified and extended the fenders and lowered the car for racing.
Torquing those Lug Nuts... Doc Zaius Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-13-2007 12:19 PM
Cheap Lug Nuts? KwonSau Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-06-2007 12:51 AM
How to remove the Nut on the top of the shock tower hystria DIY / Maintenance / Service 29 12-08-2006 09:30 PM
5 lug adapter? funkstrong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 10-21-2006 04:49 PM
Lug Nuts for Konig Helium Wheels? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-19-2006 05:58 PM
