Old 07-13-2007, 03:54 PM   #1
joey1320
joey1320's Avatar
Drives: Yaris LB
you will have to disconnect the battery. remove the airbag and the steering wheel. you'll need an adapter of some sort to install the aftermarket steering wheel.
thats it pretty much. and i'll rather not have an airbag on my car. i have seen what they can do and i'll take my chances with the seatbelt on. planing on removing my stock wheel and going with a momo also, great quality.
joey1320 is offline   Reply With Quote
Old 07-13-2007, 07:22 PM   #2
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
Originally Posted by joey1320 View Post
. i have seen what they can do and i'll take my chances with the seatbelt on..
please provide some links, I'd like to read up on this claim of yours... I have seen what they can do also, and thats save your head...
punch is offline   Reply With Quote
Old 07-13-2007, 09:00 PM   #3
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
lol i have to agree with not having an air bag. i hate to say it but most times your face is hurt more with the bag than without. that bag deploys in milliseconds and ive seen a few friends including myself get facial burns due to it. just wear your seatbelt thats all. so whatever not to get off topic... they sell adapters that keep the srs drivers airbag circuit shorted (simulates there being an airbag present) just search sites that carry hubs and steering wheels, easy to find. and its pretty difficult to blow-up an airbag installing a st.wheel. unless your applying voltage to it, which if you are your insane. some details may be off but most cars are the same.
1.disconnect the neg. battery cable and wait for 2min. straighten wheel so it is at 12 o'clock
2. unplug the srs connector at the bottom of the steering wheel. it is yellow
3. there should be 2 torx bolts one on each side of airbag, remove them.
4. pull off airbag.
5. remove wires for horn .
6. mark steering shaft and hub for alignment for later when putting in new wheel. remove steering hub bolt, usually 17 or 19mm
7. use a pull hammer to remove wheel, but if not available with 2 hands pull wheel towards yourself, might have to rock back and forth a little . it might be tough, so be carefull not to smack yourself in the face with it when it pops off its not that bad really, anyone here can do it. the most important part it making sure the new wheel is aligned properly.
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 07-14-2007, 02:48 PM   #4
joey1320
joey1320's Avatar
Drives: Yaris LB
sorry man i don't have any links to back up my claim but i have friends who have had accidents with and without the airbags on their cars and the ones with the airbags ende worse than the ones without.
maybe just crazy luck, but i really don't care, i'm going aftermarket anyways.
Old 06-20-2010, 08:03 AM   #5
Thai_Dang
Thai_Dang's Avatar
Drives: 2010 Yaris 5-Door LB AT MM
Airbags
Lol search youtube for toyota yaris crash test for the most obvious proof that airbags would save you. Looks like w/o airbags, your head would be skewered by the steering column. W/o side airbags, your head would leave the car cabin and smash into whatever's out there.
A common misconception about seatbelts are that they keep you bolted to the seat during an accident. Seatbelts are there only to slowly reduce your traveling energy, just like car crumple zones. Your body is still allowed to travel to extend the distance in which you're decelerating. If seatbelts were totally restraining, you'd suffer massive internal injuries imho. The driver side definitely needs an airbag, because the steering column is so close, lots of potential for skewering.
Keep your airbag please. If you mod, mod at your own risk, but don't advise others to disable things that would save their lives if they personally aren't modding.
Thai_Dang is offline   Reply With Quote
Old 07-22-2007, 09:32 PM   #6
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
In this case, I'll strongly suggest replacing the stock seatbelt with a 5 points harness. Stock seatbelt is modified to work with the airbag. Take a look at crash test videos. The upper part of the body is NOT retained by the diagonal belt. The upper body always moves towards the steering wheel and impacts the airbag.
Some time ago, a guy in a civic had a frontal crash at 35mph. His honda civic had aftermaket steering wheel - no airbag. His girlfriend walked away, but the guy had thorax injuries - broken ribs - after hitting the steering wheel even though he was wearing the seatbelt. The car had only front damage.
No airbag = the head/thorax will 100% hit the steering wheel in a crash at 15mph or more. Take care
hystria is offline   Reply With Quote
Yarisworld.com DIY Manual v3 vodkalush DIY / Maintenance / Service 101 06-25-2024 01:10 AM
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 07:40 AM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 06:43 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
Yarisworld.com DIY Manual v3 vodkalush Downloads for Registered Members 30 01-21-2007 11:54 PM
