Old 07-14-2007, 02:36 AM   #1
rage2
Drives: 07 Black Yaris 5D
Cool DIY: JDM RS Tail Light Installation
I searched and couldn't find an install guide for these things, so I decided to make one myself. I'm in IT, so when it comes to installing stuff, I suck. I can build a secure multi-site VPN, but I can't change my own oil. This install is mega easy... was going to get my friend to help me with but I was impatient.
Stuff you'll need:
JDM RS Tail Lights (duh!)
2 x JDM Wiring Connector Part #82824-52050
10mm wrench
Flathead screwdriver
Small allen key.
First step is to open the trunk, and get access to the tail lamps. Using your flat head screwdriver, carefully pry the top of this cover off:
This exposes the tail lights assembly:
Using the wrench, remove the 2 nuts that hold the lamp in place. Be careful not to drop the nut (hehe), it'll be impossible to find. Once the nuts are off, pull the rear cluster out. It's clipped on with a plastic piece so you'll need a bit of force. Don't worry, nothing will break. Once it's out, apply pressure to the top of this connector using your screwdriver:
And pull the plug out. Make sure when you pulled the cluster out, the white plastic clip stays on the car. If it's stuck on the cluster like so:
Pry it off with the screwdriver:
Now, the fun part. You have to wreck your stock connector on the car side. If someone knows how to do this without wrecking it, let me know! It's important that the metal clips at the end of each wire is not broken, thus, it's better to wreck the plastic clip which is replacable if you want to go back to stock. Stick the allen key into the slot with no wire and push up on it:
This lifts the top clip cover up slightly, use your screwdriver to pry the entire cover up like so:
Then pull the whole top off:
Next, use the screwdriver and carefully lift up each of the plastic tabs that hold in the metal clip at the end of the wire:
Pull the wire out carefully to avoid damage:
Once all the wires are pulled out, your clip should look mangled like this hehe:
Grab the new connector:
Look at it from the end. There are 4 holes on the top row and 2 on the bottom on each corner. I'll number them for reference.
1 2 3 4
5 x x 6
The clip looks like this:
The passenger side wires are as follows:
2 - Grey
3 - Red
4 - White w/Black Stripe
5 - Orange
6 - Yellow
The driver side wires are as follows:
2 - Green
3 - Brown
5 - Purple
6 - Light Green
Remember the white plug? Make sure it's still on the car. If you had to remove it from the cluster, slap it back on the car like so:
Plug the new connector into the car. Test the 4 lights. Reverse, lights on (dim brakes), brakes on, and turn signal. Once it's tested, push the cluster in, bolt the 2 nuts back on each side carefully... make sure you don't drop the nuts! Close the covers, and you're done!
Enjoy!
rage2
My Yaris Diary - All about my new Yaris!
My Blog - F1 News, Hotties, and Random Crap
My Site - Beyond Car Forums
rage2 is offline   Reply With Quote
Old 07-14-2007, 02:38 AM   #2
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
o man......this makes everything so much easier haha. Thanks for the DIY. Will do after i get my tail lights in late July ^^
Old 07-14-2007, 03:25 AM   #3
Now that's a quality DIY!
Old 07-14-2007, 05:06 AM   #4
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Send a message via MSN to jimcat
NICE !!!
jimcat is offline   Reply With Quote
Old 07-14-2007, 08:07 AM   #5
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Nice.
I think the rest of us were in too much of a hurry to get these installed to take photos.
Old 07-14-2007, 08:37 AM   #6
uncleyaris
Well done!
Old 07-14-2007, 08:40 AM   #7
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
really good diy, car came out great, these tails really alter the ass of the car
SPONSORED BY
Old 07-14-2007, 09:08 AM   #8
Thotprawsis
Drives: '07 Blazin' Blue LB
Great job on the DIY. Thank you!
Thotprawsis is offline   Reply With Quote
Old 07-14-2007, 09:20 AM   #9
njyaris
YARIS NEWBIE
njyaris's Avatar
Drives: YARIS 07 LIFTBACK
Send a message via AIM to njyaris Send a message via Yahoo to njyaris
nice ... sticks out a little .. gives the car a more beefy look
Hudson County, New Jersey
njyaris is offline   Reply With Quote
Old 07-14-2007, 09:20 AM   #10
MrMondayNite
Drives: 07 Yaris LB
Good Job!
MrMondayNite is offline   Reply With Quote
Old 07-14-2007, 10:51 AM   #11
rage2
hehe glad I can help others! It was pretty frustrating searching for install help, pieces of instructions were littered on several threads, and finiding english wiring instructions with proper color names was a chore too (what the hell is Ash? haha). Voltmeter is your friend!
I actually went half way thru the install before I realized I should take pics and do a write up haha.
rage2
Old 07-14-2007, 11:46 AM   #12
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Nice DIY. Thanks!
Old 07-14-2007, 03:32 PM   #13
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
Wahhh... there wasn't a DIY for these before? LoL oops would of done one way back in March =p.
Great DIY, pretty much how I did it. Looks great!
eijikikimaru is offline   Reply With Quote
Old 07-14-2007, 04:36 PM   #14
JosephDoc
Drives: 07 Yaris 3D
I believe in God.
I pray every night for a better and easier tomorrow, and now I see He just sent an angel with the message of "Vitz JDM Tail-light Mod" in detail pics, because this will save me at least uno hr some day next week.
JosephDoc is offline   Reply With Quote
Old 07-14-2007, 05:57 PM   #15
YamilR
YamilR's Avatar
That is a good DIY, now if someone could post where to buy those lights because I'm sure as hell can't find them
Old 07-14-2007, 06:03 PM   #16
uncleyaris
contact jimcat!
Old 07-14-2007, 08:28 PM   #17
Violin
Violin's Avatar
japanparts.com
Old 07-14-2007, 09:50 PM   #18
YamilR
YamilR's Avatar
Originally Posted by Violin View Post
japanparts.com
$73.96 for shipping!!!! Any vendors here on this site?
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
