Old 07-14-2007, 05:41 PM   #1
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
Originally Posted by fu_im_from_texas View Post
of the 6000+ threads on yaris world 41 are under "Tracking, Racing, Auto-X Forum"
... the majoity of yaris owners will not notice a 1% increase in accelleration
Well, there are close to 500 threads in the performance section, and most are looking for the ability to accelerate and or deceleration faster. That doesn't even take into account the hundreds of thread concerned with handling. Lighter wheels will improve maneuverability far more than a strut tower brace. So needless to say, the overall improvement lighter wheels give you would actually be interesting to more of this forums members than you first thought. I also used a 1% improvement in my example for the sake of argument. But again, a calculated rotational total reduction in weight of 80 pound from a 2300 pound Yaris is actually 3.47%. So go back and recalculate using that.
Now on to the real fun, I know this will go a little beyond light weight but smaller and lighter are even better... ;)
Using your reasoning, adding weight in the form of big heavy wheels and tires has a negligible effect. So with all the buckets of cash you get from your high paying engineering job, you go out and get some hot new 20 pound each 18X7.5s, for your luxury sport coupe Yaris. You also get yourself some nice 215/35-18s for that sweet low profile look that all the ladies like... Then there's me, with my job in the auto performance and motorsports industry. I go and find myself a set of 8.5 pound 13x7.5s along with some sweet lil' 215/50-13s.
One of my wheels and tires together runs just under 25 pounds each, while yours are coming in somewhere OVER 45 pounds. My tire is 21.46" tall, stock is 23.74"(we'll use this information later) and yours are 23.93" tall. Use this to determine the large amount of energy it will take you to turn your heavy wheel and tire when compared to my lighter and more compact wheel and tire unit. Don't forget most of your mass is almost an inch further out from center. And that's over 20 pounds per wheel and tire unit, using the simplified 4:1 ratio and multiplying it by 4 wheel and tire units we get 320 pounds! Do you still think the majority of Yaris owners will not notice a 7.2% advantage in acceleration, deceleration and changing direction?
Now, with your advanced engineering mathematics, go back up there and use the tire diameters(heights) I listed to determine my improved acceleration do to the lower gear ratio when compared to your slower than stock acceleration and higher gear ratio. And while we are dealing with tire diameters and such, determine the amount of additional energy the stock brakes will need to use to slow your taller and far heavier wheel/tire units when compared to my lil' guys.
But at the end of all this, the ladies love 18's... Luckily for me, I'm married so she'll just have to deal with my nimble little egg shaped ecno-box. And all those equations should keep you busy for awhile.
Biggie™ is offline   Reply With Quote
Old 07-14-2007, 07:43 PM   #2
gaffo
Drives: integra
Single myself - but if the "Ladies" judge a man by his car:
1. screw em
2. I'm screwed if I'm driving a Yaris - even one with 24" wheels! ;-).
You sold me!!!!!!!!
I know TINY is more fun - period. my tiny 12" Fiesta tires and my 13" Tr7 tires were pure gokart heaven.
Question and recommendations need Sir!
1. that weight you gave 8-1/2 pounds - was that for steel or alluminum (I LOVE Smootie hubcap retro look so have no need for aluminum wheels).
2. any tire/wheel brand recommendations?
3. can we go even smaller on Yaris? 12" maybe?
thank you for such an informative post sir!
gaffo is offline   Reply With Quote
Old 07-15-2007, 03:48 AM   #3
Biggie™
Biggie™'s Avatar
1: Steel wheels are heavy, always run aluminum!
2.a: The tire I basically used in my lengthy example was the 215/50-13 Sumitomo HTR 200. There aren't too many good street tires left in a 13", but you can find some nice race tires(DOT and full slicks).
2.b: There are a number of good looking super light 13" wheels , just do some research and buy what you like and can afford. Here are a few examples. They all wont work for everyone, some have rather low offsets for the Yaris, but they are still usable. I'd recommend the Lenso VPD 13x7.5, 4x100 +25 8-10 pounds? There is also an 8 pound TE37 13X8, 4x100 +20, but those are pricey. Here's a list of even more possible choices.
3: You can't find any good tires in a 12", stay with 13's.
Now, I used a 13" wheel to over emphasize my example. We could easily use a 15" wheel and still get similar results, but with more wheel and tire choices. Lets use a better fitting example for our Yaris.
Enkei RPF1 15X7, 4X100 +41 weighs only 9.5 pounds each.
Toyo Proxes T1r 205/45-15 weighs only 17 pounds each.
Those wheels/tires are 26.5 pounds each and are only 22.2 inches tall, so we still get the low weight, lower gearing and the rotational mass is still closer to center than stock.
Old 07-15-2007, 12:29 AM   #4
CaysE
That Focus Guy
CaysE's Avatar
Drives: 2004 Focus RSVT
At the risk of sounding like an ass... OWNED!
I'm sorry, fu, I'm not usually a prick...
CaysE is offline   Reply With Quote
Old 07-15-2007, 08:49 PM   #5
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
Smile
... Yaris is actually 3.47%. So go back and recalculate using that....
You are correct. I rounded 3.47 down to 3%. Sorry for the confusion... my mistake.
Using your reasoning, adding weight in the form of big heavy wheels and tires has a negligible effect. ...
I simplified the problem, by compairing 15 inch 16lb steelies vs 15 inch 10lb rims. You are very correct with your 17s vs 13s example ... your 17 vs 13, and my 15 vs 15 are apples and oranges...
Sorry for the confusion, I probably didnt make it clear that the > 1% figure only applied to 15s vs 15s.
fu_im_from_texas is offline   Reply With Quote
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
Do bigger wheels and tires improve performance Driver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 10-14-2006 06:01 PM
Enkei RZ5 wheels on Liftback kennywhy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-23-2006 04:22 AM
