Old 07-15-2007, 03:48 AM   #55
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
Originally Posted by gaffo View Post
1. that weight you gave 8-1/2 pounds - was that for steel or alluminum (I LOVE Smootie hubcap retro look so have no need for aluminum wheels).
2. any tire/wheel brand recommendations?
3. can we go even smaller on Yaris? 12" maybe?
1: Steel wheels are heavy, always run aluminum!
2.a: The tire I basically used in my lengthy example was the 215/50-13 Sumitomo HTR 200. There aren't too many good street tires left in a 13", but you can find some nice race tires(DOT and full slicks).
2.b: There are a number of good looking super light 13" wheels , just do some research and buy what you like and can afford. Here are a few examples. They all wont work for everyone, some have rather low offsets for the Yaris, but they are still usable. I'd recommend the Lenso VPD 13x7.5, 4x100 +25 8-10 pounds? There is also an 8 pound TE37 13X8, 4x100 +20, but those are pricey. Here's a list of even more possible choices.
3: You can't find any good tires in a 12", stay with 13's.
Now, I used a 13" wheel to over emphasize my example. We could easily use a 15" wheel and still get similar results, but with more wheel and tire choices. Lets use a better fitting example for our Yaris.
Enkei RPF1 15X7, 4X100 +41 weighs only 9.5 pounds each.
Toyo Proxes T1r 205/45-15 weighs only 17 pounds each.
Those wheels/tires are 26.5 pounds each and are only 22.2 inches tall, so we still get the low weight, lower gearing and the rotational mass is still closer to center than stock.
Biggie™ is offline   Reply With Quote
Old 07-15-2007, 11:16 AM   #56
gaffo
Drives: integra
i like the yaris with smaller wheels. I think the ones with the stock 14" look noticably better than the 15" ones.
just me taste. I like the 1950's smoothe hubcap look too. old school VW Beetles really look good with em.
thanks for all the feedback - I'll check out your recommendations ;-).
gaffo is offline   Reply With Quote
Old 07-15-2007, 01:42 PM   #57
Biggie™
Biggie™'s Avatar
From the sounds of it, these are the wheels you want. I have no idea what they weigh, and the smallest size they have is 15"...
Old 07-15-2007, 08:49 PM   #58
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
Smile
Originally Posted by Biggie™ View Post
... Yaris is actually 3.47%. So go back and recalculate using that....
You are correct. I rounded 3.47 down to 3%. Sorry for the confusion... my mistake.
Using your reasoning, adding weight in the form of big heavy wheels and tires has a negligible effect. ...
I simplified the problem, by compairing 15 inch 16lb steelies vs 15 inch 10lb rims. You are very correct with your 17s vs 13s example ... your 17 vs 13, and my 15 vs 15 are apples and oranges...
Sorry for the confusion, I probably didnt make it clear that the > 1% figure only applied to 15s vs 15s.
fu_im_from_texas is offline   Reply With Quote
Old 07-15-2007, 09:22 PM   #59
fu_im_from_texas
Drives: Liftback
Thumbs up You are right!
Originally Posted by cleong View Post
...Then when proven otherwise, you change tack to say that the gain is irrelevant, ....
I claimed that lighter rims would have less than 1% improvement in accelleration. Then, you suggested a 1:4 ratio, which comes to about 3.47 % improvement. Please note that you did not "prove" anything... you simply suggested a different approach ... and I assumed it to be true...
Had I known we were going back and forth over 0% vs 3.5% I would have said "You are right" a long time ago...
Old 07-16-2007, 08:22 PM   #60
gaffo
Drives: integra
sweet link Biggie thanks!
love the look.
foriegn site - no english ;-/.
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
Do bigger wheels and tires improve performance Driver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 10-14-2006 06:01 PM
Enkei RZ5 wheels on Liftback kennywhy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-23-2006 04:22 AM
