Old 07-18-2007, 01:04 AM   #1
03Z33
03Z33's Avatar
Drives: TCR10
Originally Posted by reznunt View Post
THIS is exactly what i need them for as i was going to do a battery relocation into the spare wheel well. most people think i'm asking about just front-rear distribution when i really was interested in corner balancing. i just wanted to know how far to mount the battery to the right to offset the fuel tank.
i'd love to put my car up on the scales... but i have nothing to offer you in return other than maybe a case of beer and a bucket of chicken. what's your price?
or, if you need tires (and i'm assuming you do since you track your car), i can give you my cost on tires. paint too. let me know
Just send me a PM, I'm sure we can work something out. I'll be out of town until Tuesday next week though.
As far as battery goes, I didn't bother with relocating it since it is only 13lbs. (light weight battery). I never liked the idea of having the battery inside the cabin and most times when you add up all the heavy gauge wiring and battery boxes that SCCA require, you end up adding more weight than it's worth.
BTW, the gas tank is pretty well centered in this car, just the filler is on the drivers side. If I was to mount the battery in the back, I would do it on the drivers side since that would help with your corner/cross weight the most. That's if you couldn't mount it in the center, below where the passenger feet would be.
03Z33 is offline   Reply With Quote
Old 07-18-2007, 05:26 PM   #2
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
actually, you're right about the added weight. i forgot to add the weight of the 1/0 cable, battery box, distribution block, blah blah.
also, i just got up under the car today and it's just as you described. the tank is smack dab in the center.
i think i'll just drop in a lightweight battery in the stock location and call it a day. saves a lot of hassle.
thanks for the offer though! it's the thought that counts!
reznunt is offline   Reply With Quote
Weight Savings 03Z33 Performance Modifications 30 01-31-2009 04:14 PM
How would a Yaris liftback compare to an early 80's Tercel liftback ... Yaris_Fan General Yaris / Vitz Discussion 15 06-06-2007 05:40 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
