Old 07-19-2007, 03:58 PM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
You should run 205/40/17 (slightly smaller (what I use)), 205/45/17 (slightly larger), or 215/40/17 (exact stock replacment). A 215/45/17 is really tall; you WILL rub if you lower your car, maybe even without lowering.
Old 07-19-2007, 07:33 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
205/45/17 is OEM (T-sport) @ 24.3", and this is the size you should run if you don't lower the car.
215/45/17 @ 24.6" is not much taller (1.6%), and it won't make any significant difference in height whatsoever; you'll just have a wider footprint. If you don't lower your car, you would be fine, but the sidewall may poke out a bit up front with a 7" ET42mm, and will definitely stick out with with ET38mm.
So, as Peter indicated above, you should run 205/40/17's if you plan to lower your car. You can stagger the sizes front to rear if you like. Staggered wheel widths, offsets, and/or tire sizes are a common application on the Vitz in Japan.
You could run 205/40's up front and 215/40's in the rear. This would look excellent and compensate (5mm's) for the obvious FR/RR difference.
FS Brand New Stock rims w/ Tires FlintS Items for Sale by private party 10 09-24-2007 08:22 PM
FS: 17'' Motegi MR7 Rims and Khumo Tires Sabretooth Items for Sale by private party 11 07-02-2007 02:55 PM
Need help when ordering my tires and rims thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-26-2007 09:40 PM
FS: 07 yaris RS stock rims n tires thegame11 Items for Sale by private party 5 04-15-2007 01:25 PM
New rims - old tires littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-15-2006 06:51 PM
