Old 07-20-2007, 02:09 AM   #1
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
Originally Posted by Pavel Olavich View Post
for rear wheel drive cars, 50-50 is more important....but a front wheel drive "pulls" you along, and as far as handling goes, curves and such, you don't want 50-50 with a front wheel drive car....rear wheel, perhaps.
"If your car has a 60% front 40% rear weight distribution, then when you corner, your outside front tire will be the most heavily loaded. A 50/50 split is desirable for many reasons, one of them being that when cornering, BOTH outside tires - not just one - will have the bulk of the load."
this quote i agree with. it tells me why i will see less understeer at the limits with a 50/50 rather than a 60/40.
maybe you can better explain your reasoning behind favoring a front weight bias in a ff car. anyone feel free to chime in to set me straight. i still believe that 50/50 is best for any drivetrain when it comes to cornering.
reznunt is offline   Reply With Quote
Old 07-21-2007, 12:31 PM   #2
Pars
Drives: 07 Yaris Liftback
I agree with Pavel, having some extra weight up front on a front-drive is useful. However, there's always a trade-off. For instance, a very tiny car, like the Yaris, might need a more balanced weight distribution, since stability is a priority over traction at the lights (or on the snow).
In the heavy weight category, the rear drive will probably have an easy advantage. But, a longer wheelbase, lightweight front-drive could be tweaked to make maximum use of the available rubber, while still returning great dynamics and not put undo pressure on the front tires. I wonder how a Celica GTS, that's tweaked for the track, would fair against the Mazda Miata. I'd bet on the Celica.
Pars is offline   Reply With Quote
Weight Savings 03Z33 Performance Modifications 30 01-31-2009 04:14 PM
How would a Yaris liftback compare to an early 80's Tercel liftback ... Yaris_Fan General Yaris / Vitz Discussion 15 06-06-2007 05:40 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
