![]() Drives: Yaris type E M/T Join Date: Jul 2007
Got 142hp on mine. Expectation will be 150hp or over. I am not planning to get a turbo or a supercharge for my engine, let's see what's the most of our yaris' 1NZ-FE engine can do shall we????
N/A is the best!!!!!!sorry guys, by the way it's not my decals that make my car can reached the above hp |
#2 | |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
you are pushing 142 WHP? all motor? List your mods
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
This guy must be an Indonesian prince or somethin'.....
Year: 2006 Model: type E Color: red Transmission: M/T Interior seat/trim color: black fabric Package Options: Exterior Modifications Exterior: VITZ RS Original Front Bumper VITZ RS Original Side Skirt VITZ RS Original Rear Bumper VITZ RS Original Rear Tail Lamp VITZ RS Original Rear Reflector VARIS Carbon Bonnet TOMOKI Short Antenna PHILIPS Xenon Light 4300K TRD Body Stripping ADVAN RGII 15x7.0 +35 Bridgestone S-02 195/55/15 Volk Rays Daytona Racing Nuts Interior Modifications SPARCO Suede Steering Wheel TOM’S Horn Button TOM’S Shift Knob DAIKEI Quick Release Steering Wheel HKB Bosskit with special Airbag Sensor BRIDE Ergo II Racing Seat BRIDE Low Position Seat Rail + Bracket PIVOT Shift Lamp PIVOT Tachometer BLITZ DCII Oil Temp Meter Performance/Handling Modifications Engine Package : TRD Exhaust Manifold TRD Street Clutch (Organic) TRD Light Weight Flywheel TRD Quick Shifter TRD Thermostat TRD Oil Cap Tom’s Radiator Cap TRUST Power Extreme II Exhaust TRUST AIRINX Air Filter Kit + Cold Air Box TRUST Oil Sensor Adaptor NGK Iriway 8 Spark Plug Billion Air Funnel 75 Billion Air Duct 75 Zero-1000 Power Neo Hot Inazma Eco C-One Engine Mounting C-One Crank Shaft Pulley SARD Magnetic Oil Filter FK Massimo Racing 3 Engine Oil 7.5/40 OGURA Reservoir Tank Cover Carbon Printed Engine Cover Engine Port and Polish Engine Compression increased 0.6mm Engine Balance DASTEC Unichip Type Q Fuel Management System suspensions: Tanabe NF Coilover Kit Suspension (F:6kg/mm; R:8kg/mm) Tanabe Front Tower Bar C-One Under Brace C-One Rear Monocoque Bar Brake System: ENDLESS SSS (0-500C) Brake Pad ENDLESS DOT 4 Brake Fluid TOMEI Braided Brake Line Future Planned Modifications increase more hp to its max with N/A engine
SPONSORED BY
[QUOTE=brickhardmeat;113987]This guy must be an Indonesian prince or somethin'...
hahahaa great comment...I'm not a prince for one, as I'm not a guy!!! but I own a modification shop in jakarta though, modification is my hobby |
#5 | |
Lonesome Cowboy
[QUOTE=red-jdm;113990]
SPONSORED BY
Are you asking if I had my car dyno tested on wheels or engine? On engine of course, not on wheels. The standard car (thai/indonesia's yaris) comes with 109 hp on engine, listed on its specification.
You can look at my mods in my profile |
#8 | |
der Zeck
I understand the probibly dynoed it at the crank when they did the port and polish/balance but WHP is what matters.... Yes the Yaris make 109HP at the crank from the factory, but it only puts about 87-90 to the ground..... so you may want to get your car dynoed for some more accurate # at the wheels
| Rota "Group N" Wheels | Pepe | California | 27 | 09-08-2007 03:09 PM |
| Looking for Sedan Modifications... | PMCRW | Cosmetic Modifications (Exterior/Interior) | 5 | 06-15-2006 07:19 PM |
| Looking for Yaris Sedan modifications! | PMCRW | New YARIS Purchase Forum | 1 | 06-15-2006 12:51 AM |
