Old 07-22-2007, 05:36 PM   #1
ya_RS
ya_RS's Avatar
Drives: 07 RS
with my car not being as low...
205/50/16
or
205/50/195
cause i was thinkin 195 like Cali_yaris
ok, here you go, the new one, then the one that rubbed.
Seems like that bit of change in the sidewall did the trick:
195/50/16 Kumho ECSTA RSX:
205/50/16 Falken 512
Honda to Toyota... lets see how this plays out
ya_RS is offline   Reply With Quote
Old 07-22-2007, 05:49 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
205/50/16
or
205/50/195
If I recall, cali yaris is running 16x7, ET38's all 'round with 195/50/16's.
Initially, he had a rubbing problem running 205/50's, but solved it by switching to the 195/50's. I'm guessing it wasn't a height issue, but a width issue that caused the rubbing. Check this out with him.
If you plan to run ET42's, you should be fine with 205's, provided you haven't really dumped your car.
