![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
Well, I do have an exhaust, the stock one ;-) and the hitch is not in the way at all, the main horizontal bar goes right above the lower bumper edge. There is one thing I can't figure out from your pic, how far back that attachment rod goes. If the attachment points are the same as for the stock exhaust, I don't see a problem. If you can upload a picture from a slightly different angle (push the camera deeper under the car, like 90 degree with the exhaust) I will be able to tell better.
My hitch is from Draw Tite, but I understand there are different models out there and they even have different attachment points. Oh, btw, what size rims and tires do you have? I just got a new set for my Yaris and was a little afraid to go with a thin tire... |
#2 | |
![]() ![]() ![]() Drives: BSP Yaris LB 2007 Join Date: Apr 2007
![]() Yaris Prime, I think your Curt will work too. And judging by the attachement points it looks easier to install than the Draw Tite however I think those lower openings are tow points but I guess if you need a tow they can do it thru a receiver... |
I finally found the pics I took when installing the electrical harness for towing. I wanted to hide everything, so you can't see it when it's not in use. So I took out the panels as you can see in the first photo and I unclipped the side panels, so that I could lay the wires underneath and out of sight. You must be careful with the side panels, because you must push the edge toward the inside, to unhook it, you can't simply pull on it after unscrewing the bolts. This hook is I'd say at the same height as the top edge of the tail lights. You'll see it if you pull the panel just a little bit and peek inbetween.
![]() The day before I had figured out which wires are the stop lights, brake and turn signals, so with that note in hand I spliced the wires. The kit had an extra long green wire for the right turn signal. The white wire (ground) is attached to one of the bolts securing the tail light. ![]() And this is the end result, the cable is resting inside the spare wheel when it's not in use, out of sight. I managed to fit the controller module behind the back panel, although I had to cut a little piece of one vertical rib, to avoid the panel forming a bulge over the controller.
fmicle - how do you like that bikerack? is that a Bell from Wallyworld?
How's it on the freeway? pretty stable? I like the fact the arms are spread out more than high end racks. |
#5 | |
The rubber rings that the straps go into and velcro back onto themselves are broken, but the straps are long enough so I can lead them around the bar - and I actually feel better this way, much stronger than a little piece of rubber. I wanted to get a ski rack to attach to it, but unfortunately, I couldn't find anything that fits this model. Yet
Thanks, I was looking into all kinds of racks, lots of them have fold down arms and the 'tray' style I feel will scrape because I'm lowered.
The Bell with the inability to fold arms makes it lighter and prolly stronger. I'm a leaning towards that. More features IMO = more weight and $350 racks will need to be locked down. I think the bell can handle 100 lbs while the folding arms around 70 or less for 1 1/4". |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
I'm too lazy to go out to the car at this hour, but what is the length between
mounting points? or how wide is this hidden hitch?
![]() Drives: Yaris RS 2007 Join Date: Jul 2009
Hi guys,
I've a question about the curt hitch (I've looked all over here and couldn't find the answer). Does it feet on an RS model Yaris LB 2007, because of the skirt, it seems that it is a pain in the bu.... to get one install here in MTL. Thanks Cheers |
| Genuine Toyota Hitch for Yaris now available in Canada | voodoo22 | DIY / Maintenance / Service | 8 | 04-22-2014 07:50 AM |
| Failed Hitch Installation | fmicle | DIY / Maintenance / Service | 7 | 08-11-2010 03:15 AM |
| Towing Hitch for a Yaris | fmicle | General Yaris / Vitz Discussion | 1 | 05-16-2007 07:07 PM |
| System is installed! | Venom | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 01-28-2007 06:06 PM |
| Tanabe NF210's installed...got a question though | Terrorize | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 09-29-2006 07:45 AM |
