still wheel confused..
after looking at garage pics and reading stuff here, still confused and don't want to get the wrong sizes
should i go with df210 and get 15inch rims? (how about 16's) or go with nf210 and get 16inch? what size tires...???
. Last edited by wushumasterku; 07-24-2007 at 04:07 AM. |
People have DF's all the way up to 17 inch rims and up. They have the dfferent sizes cause people like to run them on the track and people like me just for everyday driving dont care as long as the rim and tire lasts if you drill a pothole.
If you take the height if a rim and a low profile tire they are about the same as the 15 or 14 inch wheel and tires with a taller side wall . The problems I believe people are running into is the size of the tires and the offset of the wheels causing rubbing. I had 17 x7 offset +40mm with 215/40/17 tires. The only rubbing was in the back. The outside of the sidewall barely rubber the inside of the wheel well. |
#3 | |
Q(','Q)
#4 | |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
everything depends on what you like, what you can afford, and what kind of driving you plan on doing with them... click on my signature for some tire options from 14-20 inch wheel sizes
#5 | |
![]() Drives: Yaris Join Date: Jul 2007
Tire Size Michelin Pilot Preceda II 205/50/16. I think its a perfect combination. But for myself, I would preffer to use DF210 and 15inch on 195/55/15 tires. or better use Sustec Pro NF but its all up 2 u. |
#6 | |
![]() ![]() Drives: 07 RS Join Date: Jun 2007
Honda to Toyota... lets see how this plays out
yea, looks good but what drop is this? do you know?
#8 | |
actually which one gives better mileage?
#9 | |
![]() ![]() ![]() Drives: '07 Blazing Blue LB, '09 Jetta Join Date: May 2007
, i've been in your position before...
current: '07 Yaris LB - '09 VW Jetta ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi |
there is going to be many factors involved to get a great setup...
for example http://www.yarisworld.com/forums/showthread.php?t=7489 With RIMS.....the bottom line here is --get as close as you can to your tire height --get an offset that wont let the rim sit to far in or out the wheel well --get lowered to your desired height... after lowereing.... and if there is rubbing --roll fender --the rubbing is due to a high bound/rebound on the spring so get aftermarket shocks to stiffen the ride --rubbing could be in the well due to wrong offset and its hitting the inside of the wheel well and there you have a lowered car with the rims you want and there are other / many other sulutions and factors .... youy can even go extreme and have a WIDE-body vitz
#11 | |
![]() ![]() Drives: 07 Bitchin Blue HB Join Date: Jul 2007
Can you recommend any gallerys to look at? |
naw... its a car from Japan cause it has the rear disc... you know they alwasy get the advanced stuff... lucky guys
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 02:05 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 09:30 PM |
| WANTED: 4 Wheel Covers | galaxyhillvt | Items for Sale by private party | 2 | 07-11-2007 05:05 PM |
| Yaris wheel rate ratio (06+) ? | dsc_pat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 07-05-2007 06:43 PM |
| Yaris wheel sizes and XA (ist) wheel sizes | Master | General Yaris / Vitz Discussion | 10 | 04-18-2006 12:38 PM |
