Old 07-27-2007, 09:33 PM   #1
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
[QUOTE=Astroman;108102]
After poking around on the engine bay side of the firewall I saw a rubber stopper and removed it finding the perfect sized hole roughly a half inch in size on the passenger side, perfectly placed where the inverter was going to be in the void behind the glovebox, next to where the cabin air filter is located.
just a side note, for those with airconditioning this plug is where the drain line runs out.... also astroman, you better buy a grommet for that hole, or it will eventually rub away at the wire....
punch is offline   Reply With Quote
Old 08-08-2007, 01:05 PM   #2
Astroman
Modded Moderator
Astroman's Avatar
Oooh, good point! Didn't think of that. Thanks for the heads up. Also I have air conditioning but the only thing was the rubber stopper, I didn't see any drain line.
DIY: Discreet Mounting of 12V adaptor for the Gtech & V1 H8SGAS DIY / Maintenance / Service 7 09-26-2006 02:50 AM
