Old 07-28-2007, 03:33 AM   #1
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
2hp is probably not feelable, if that's a word, unless you have a really sensative ass I'm guessing it's a placebo effect type of thing, you expect to feel more power, thus you do...
It's scary to think that half the people surrounding you are below average...
jdium is offline   Reply With Quote
Old 07-28-2007, 05:56 AM   #2
Astroman
Modded Moderator
Astroman's Avatar
Well, I did manage a 17.356 quarter mile time, about a half sec quicker than stock.
Old 07-28-2007, 06:27 AM   #3
jdium
Mr Attitude
jdium's Avatar
Half second quicker than YOUR stock time, or some magazines stock time? Just askin, cuz 2 hp is worth about nothing in the 1/4 mile. Even if you want to consider it a 2% increase, that means you would cut .35 of a second off you're time, all things being equal...but if you happen to have a slightly lower temp, or a slightly higher tail wind, or a slight change in relative humidity, or a slight change in tire pressure, or a little more or less caffeine in your quick twitch system, or a stickier track, or a slightly higher rpm launch, or just Zeus helping you, going a half second faster than 17.856 is like a 350 lb chick losing 12 lbs, she's still fat...
Old 07-28-2007, 07:15 PM   #4
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
An aftermarket lightweight pulley doesnt give u more HP, it just revs up faster thus giving u faster speeds....
an exhaust will give u hp gains thus more airflow, so will a muffler.......
Old 07-29-2007, 02:41 PM   #5
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
Lightweight and underdrive don't create more HP but they do free up HP lost due to parasidic drag. Your engine makes the same power, but more of it is transmitted to the wheels. Its the same thing as a lighter flywheel, lighter wheels, or a more efficient transmission - none make more power, but they will show up on a roller dyno. Everything but the wheels will show up on a hub dyno.
Faster revving will not get you to speed faster, only more wheel HP. And it definalty will not let you go faster - thats either a function of HP and drag OR transmission gearing. Faster revving will give you better throttle response and worse shifting till your used to it - revs will drop faster too, less mass=less kinetic energy.
WRBlue is offline   Reply With Quote
A good aftermarket exhaust... whooppee777 Performance Modifications 4 04-06-2007 02:12 PM
Aftermarket Power Windows?? blazerscoach New YARIS Purchase Forum 7 02-18-2007 06:49 PM
What aftermarket exhaust will fit the Yaris Sedan? dngz Performance Modifications 2 10-02-2006 01:41 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
