#1 | |
Scroll down on the first page and you'll see dyno sheets from an Acura TSX and Lotus Elise. If NST can make power on a Lotus, you think they can handle your Yaris? |
#2 | |
Mr Attitude
Drives: Blazing Blue 5 Spd Join Date: Jun 2007
It's scary to think that half the people surrounding you are below average...
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: NST CARS: S13 AE86 ANT10 AW11 Join Date: Dec 2006
What happens around 6,000 RPM is the Toyota Variable Valve Timing (VVTi / VVTLi) that kicks in. The engine makes a lot more power from 6,000 to redline, as evident in the graphs there. The same thing can be seen in the dyno chart above posted about the Civic Si and the Acura TSX. Vtec kicks in around 6,000 RPM and power increases significantly. As you can see, NST pulleys continue to free up power even beyond this point. |
