![]() ![]() ![]() ![]() ![]() Drives: 06 3-dr auto RS Join Date: Jan 2006
Follow up to Post # 1609:
Fuel Cost C$37.39 Distance travelled 552.6 km 343.39 miles Fuel Amount 36.62 litres 9.68 US gallons 8.06 Imperial gallons Cost of Fuel $1.02 per litre $3.86 per US gallon $4.64 per Imperial gallon Fuel Economy 6.63 litres per 100 km 35.49 miles per US gallon 42.63 miles per Imperial gallon Mileage Costs 6.7662 ¢ents per km 10.89 ¢ents per mile Car was used as and driven like a family car and was driven by wife 95% of the time during the period covered. Regular fuel used. Tire pressure @ 34 PSI all around. Normal maintenance schedule followed. City/highway = about 40/60. Lots of road works. Load = 2 people with groceries and/or belongings, plus or minus. AC on about half of the time. Other factors basically unchanged. Last edited by swng; 09-20-2007 at 08:04 PM. |
toyota
47 MPG , 5 l/100km wait is this for the d-4d engine.. isnt that just about 86 hp on it..
I think Bredayaris has a diesel engine. Diesel engines are known for their good fuel economy. Although the d-4d engine may not have as many hp as our gas engines have, relatively speaking, it enjoys an abundance of low end torque which can compensate somewhat for its limited power.
I believe if Bredayaris tries harder, he can achieve an even better result. |
Yaris fuel economy
I drive almost 100% city driving (under 50 mph) and when driving normally (accelerating moderately hard, but not stomping it), I get about 33 mpg. When I barely touch the pedal, shift at about 2300, then I get about 44. My record on gas is 47 mpg, awesome for even a hybrid!
Also, to figure out your rpms at a certain speed (for those like me without a tach), I went to vehix.com and found the gear ratios for my manual transmission (the autobox ratios are also there I believe), and then plug them into a gear ratio/tire size/rpm speed calculator. At 40 mph in 5th, the engine is at 1800, at 60, it's at 2800, and at 80, it's at a lofty 3600. But on a trip to Canada once, crusing steadily at 82 on flat terrain, I still averaged 37 mpg! |
![]() ![]() ![]() Drives: Toyota Yaris 1.3 vvti cvt Join Date: May 2007
@ swng
My Yaris D-4d has 90 hp and 140 lb-ft instead of 106 hp and 103 lb-ft. 0-60 mph isn't that good as for the 1.5l gasoline engine, the diesel does that in 10.7 sec, but the high torque is really impressive. It pushes you in your seats. I think i can easily get a better mileage, but remember the Netherlands is one of the most populated countries in the world, everybody is in a rush. Our maximum speed at the highway is 75 mph, in the US slower correct me if i'm wrong. My colleague has driven for over 30 years in the US and he says it's a really slow way of driving instead of in Europe, not even talked about the Netherlands ;) But if i drive 62 mph i can get easily 52 mpg or better. |
Thanks Bredayaris for the additional information. Your fuel economical and yet fun to drive diesel Yaris is a very enviable car. Hope you enjoy your visits to this thread.
Safe/save and happy motoring!
![]() ![]() ![]() Drives: 2007 Yaris S Join Date: May 2007
Just got back from a 2,000 mile trip. Two people plus about 200 lbs. of gear @ about 73 MPH and still averaged 40 MPG on the dot.
********************************* "Emancipate yourselves from mental slavery; None but ourselves can free our minds." |
I dont get it, I have nothing in my car, keep gear changes between 1.7 and 2.7k on my automatic, and drive at max 70mph, but usually 55-60. And I dont get anything above 32MPG.
The most I ever got was 35-37mpg when I first got my car, and only maybe 1-3months later it went downhill. From there its been the same, 25-28mpg winter, and 28-32mpg summer. I have done all services on the car, including changing spark plugs, switch to synthetic oil, and changed tranny oil. |
#9 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
#10 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
still getting 29.5 mpg city in my 2001 civic 4-door hehe
I'm trying to keep up with you all... |
Five ways to greenify your car:
http://en.autos.sympatico.msn.ca/caa...mentid=5286407 Better fuel economy will come as a by-product. Just one more reason to try harder to save earth, and gas and money of course .
I have been trying not to accel fast, and living in a packed place/close to the city, I have 99% of people who always speed. And this includes having to rev to 2000rpm minimum when allowing it to change gears because the guys behind will have a titty attack and almost hit my bumper.
As for driving the speed limit, it says 50mph, most people during the day do 60-65, and at night up to 70. So you see its hard for me just to even do 60mph at times. But even so, I tried my best and only got 32mpg. Mind you this is also after taking out two 12" sub's and changing back to stock rims/tires. I guess Im just unlucky with my car? Also, I have now about 24,000 miles on the car. Last edited by Lafiro; 09-24-2007 at 12:15 PM. Reason: Miles on car |
#14 | |
toyota
1. check tire pressure! add about maybe 5 psi over stock. 2. and air filter may be the cause as well... |
#15 |
![]() ![]() Drives: 07 5 door Hatchback Join Date: Jul 2007
Lafiro,
When we quote mpg, check the location of the poster. Canadian posters may be posting imp mpg. 40 imp mpg is about 33 us mpg. Quoting L/100km or even kml is more accurate as the litre is standard. |
#16 | |
I'm averaging over 44 us mpg and over 50 imp mpg. |
#17 | |
You're still getting good FE, but you would do better if you didn't drive faster than speed limit and accelerated slower. |
#18 |
![]() Drives: Toyota yaris hatchback Join Date: Sep 2007
I find the most i have gotten with my tank is 640km, and my first bar on my tank gose away after 140 km, the second one drops at about only 80 to 90km
