Old 08-01-2007, 06:40 PM   #1
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
Finally got the wheels, 17x 7, 40 mm offset OZ Racing Supert. WRC wheels w BFGoodrich g-sport, 215/40ZR17, with Tein S-tech 1.9 in dropped
Cold Air Induction|Blitz SUS POWER Air Cleaner System|2.4L 2AZ-FE Throttle Body|Blitz Compressor System|Full Light weight pulley kit|GReddy Ti-C exhaust System|Blitz Throttle Controller|T/B Coolant Bypass + Gasket Trimmed|Weight deduction|Exhaust Manifold|Center pipe|PCV Bypassed
Yaris T-Sport is offline   Reply With Quote
Old 08-01-2007, 07:35 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
[QUOTE=Yaris T-Sport;119100]Finally got the wheels, 215 40R17, with Tein 1.9 in dropped
/QUOTE]
Looks first class fabulous!
Old 08-01-2007, 11:43 PM   #3
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
dude...that is awesome looking Yaris!!..damn Longo..they should have given me the red one...
btw,
with that size of tire...is there any rubbing?
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-02-2007, 12:36 AM   #4
seanele
seanele's Avatar
Blue one is an awesome color too there is no rubbing at all
I use this Tire Calculator on
http://www.discounttire.com/dtcs/infoTireMath.dos
the Overall Diameter of 215/40R17 is only + .03 compare to the OEM 185/60R15
, which is the closest overall diameter you can get to our OEM wheels in a 17in wheel (If your speedometer reads: 65, You're going approximately: 65.08)
205/45R17 would be + .52 bigger than the OEM 185/60R15 (If your speedometer reads: 65, You're going approximately: 66.42
the Tire Calculator is really helpful for you to pick the tire size thats as close to the OEM size as possible
PS. Blazing Blue and white wheels match up real good too
thanks..
i will seriously consider this white color rims + Blue Yaris..
Since my Yaris is not as fast as those frikin' Civics, i'll make sure it will beat them at least in looks.
good think i haven't place the order for the Konig Rewind...
Old 08-16-2007, 02:54 PM   #5
jm1681
Janghwa, Hongryeon
jm1681's Avatar
Drives: 20th AE VW GTI
Awesome
22B | 藤原とうふ店 | Fatal Frame | 呪怨 | 장화,홍련 | Strong Bad
How to survive a Zombie attack
"The inerasable scars, left by the palms of my hands"
365tuners
jm1681 is offline   Reply With Quote
