![]() Drives: stock for now Join Date: Jul 2007
The drilled and slotted rotors aren't done that way to only dissipate heat. The slotting/drilling also gives the gases created from the pads under high heat (or at another extreme rain water on the rotor) a place to escape rather than trying to push the pad away from the rotor. I agree though...on a street driven vehicle your not going to net any real benefit. Crossdrilling will, however, lose you a little rotating weight. Probably not enough for you to notice...but I just thought i would put that in there
| Feeler: Brembo Max brake rotors | eTiMaGo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 08-07-2007 08:05 PM |
| Slotted Brake Rotors | Violin | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 04-21-2007 11:16 PM |
| Cross Drilled Rotors for yaris | Adriaan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-16-2007 03:27 PM |
| Performance Brake Rotors | YamilR | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 09-22-2006 05:31 PM |
