Old 08-08-2007, 08:15 PM   #25
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
positive trigger = a +12V wire is given power when the switch is on.
negative trigger = the ground wire is active when the switch is on.
toyotas are mostly negative triggered. Makes the harness a little different for constructing.
The high beam will get the common 12V and the high beam ground
The low beam (HID) will use a relay harness which will use the low beam and high beam grounds as a trigger wire.
Black Yaris, what are city lights? Do you mean the parking light? Is it a bulb that turns on when you flip the headlight switch one notch, and stays on during the low-beam switch?
taKuto is offline   Reply With Quote
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 07:55 PM
Southeastern Power Package with Alloy wheels? Where is my Yaris? New YARIS Purchase Forum 0 03-23-2007 07:40 AM
convenience vs. power package jeff_o General Yaris / Vitz Discussion 25 10-17-2006 10:04 AM
Is concenience package and power package the same thing on liftback ? YarisBlazer General Yaris / Vitz Discussion 4 07-21-2006 11:58 PM
Waiting for the Taiwan Yaris heybai General Yaris / Vitz Discussion 13 03-12-2006 07:26 AM
