Old 08-09-2007, 02:23 AM   #1
d2dailly
Roar?
Drives: 07 White LB Yaris
Send a message via AIM to d2dailly
release the clutch and then press the clutch the syncros arent ligned up... first isnt syncronized so its what black yaris said about over-revving
d2dailly is offline   Reply With Quote
Old 08-10-2007, 03:53 AM   #2
Edd
Drives: None
Careful about what you say. 1st IS syncronised in the Yaris, and has been in most cars for at least a decade. That's why he felt resistance, because the syncronisers were doing their job. If there weren't any (ie, straight cut gears), they would grind and make a horrible sound.
By releasing the clutch in neutral first, you get the layshaft to a similar speed to the output shaft, meaning the syncro's job is easier. Do completely rev match, you must blip the throttle when you are in neutral, then clutch in and go back to first. This shouldn't be necessary though. Just make sure you are SLOW to go into first, be gentle and you won't wear your syncro.
Edd is offline   Reply With Quote
Vitz (1st Gen) Tid Bits Airknight General Yaris / Vitz Discussion 1 03-09-2017 04:24 AM
Vitz (1st Gen) Tid Bits Airknight DIY / Maintenance / Service 0 06-25-2007 05:12 AM
speedo gear AlanSRT4 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-27-2007 10:37 AM
Which Redline gear oil is the best for our Yaris? stevencyt DIY / Maintenance / Service 0 03-13-2007 11:11 PM
clicking into first gear tekmoe General Yaris / Vitz Discussion 9 11-01-2006 02:44 AM
