Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Central and South America
Old 08-10-2007, 02:38 PM   #1
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
S-AFC = Super Air Flow Converter
Es un piggyback el cual puedes utilizar para afinar el air-fuel ratio de tu carro modificando la curva del combustible con exactitud y precisión.
Sorry pero no encontre un link en español
AFC Air Flow Converter
How does the AFC Air Flow Converter Work?
The A'PEXi Air Flow Converters work by intercepting the signal between the car's air flow meter and the ECU. The Air Flow Meter is the device that tells the ECU how much air is entering the engine so that the ECU can add the correct amount of fuel.
The ECU calculates the proper ratio of fuel to air for a stock, unmodified engine. Certain engine modifications can cause the dynamics of the engine to require more fuel. In this case, there are two common options for modifying the amout of fuel being input into the engine. One can either install larger injectors or increase the fuel pressure to the stock injectors is increased.
Since the stock ECU thinks that it knows how much fuel it is putting into the engine based on the stock injector size and the stock fuel pressure, changing either of these will result in increased fuel. You may get lucky and just pick the perfect injector or fuel pressure that gives you the perfect air/fuel ratio. You may also get lucky and pick this weekends winning lottery numbers. In either case I wouldn't bet the farm on it. The Air Flow Converter gives you the means to adjust the amount of fuel that the ECU injects into the engine by modifying the signal from the air flow meter. This is done a specific RPM levels. This way you can tell the engine that a certain amount more air is flowing into the engine as a specific RPM than is really entering the engine, and the ECU will add that much more fuel. Decrease it at another RPM level and the ECU will decrease the fuel into the engine.
Estas son unas fotos del aparatito,
la mia es de la primera generacion la cual ya esta descontinuada, la version mas reciente es la Apexi SAFC NEO
It's a Vitz!
Vic-2NZFE is offline   Reply With Quote
Old 08-10-2007, 04:19 PM   #2
carlosh
carlosh's Avatar
Drives: Yaris Sedan 2005 Motor 1NZFE
Send a message via MSN to carlosh Send a message via Yahoo to carlosh
ta pretty el aparatito ese saee....
Cuando sea grande quiero tener uno de esos
Yaris/echo 1NZFE NCP12
-> TEIN High-TECH spring, Tower bar Generic, HOTCHKIS Sway bar
-> TRD Performance air filter, Stage 1 Gripforce F1 clutch
carlosh is offline   Reply With Quote
Toyota Yaris S Mod jamal1984 Performance Modifications 10 01-07-2007 02:48 PM
