Old 08-12-2007, 12:29 AM   #1
I thought our ECU compensated/disabled attempts with eManage?
Old 08-12-2007, 01:07 AM   #2
joey1320
joey1320's Avatar
Drives: Yaris LB
it does. the only way i know is to remove the front o2 sensor which will throw a cel but then the ecu won't be able to reset the adaptation values.
T&A said he used some kind of special unit for his turbo matrix but i'm not sure what it was called and if it will work on our cars. it supposedly allows you to boost the car without having to remove the front o2.
joey1320 is offline   Reply With Quote
