Old 08-13-2007, 07:30 AM   #1
Nabisco
Nabisco's Avatar
Drives: '08 Honda Fit Sport
Send a message via ICQ to Nabisco Send a message via AIM to Nabisco
Looks good! I like that intake design!
An oil catch can is usually to go between the valve cover and intake pipe or PCV valve and intake pipe. It's function is to remove oil and or oil vapor from positive air coming from the valve cover and oil vapor induction in the intake. Usually you don't install these unless you have blow by. I don't have blow by on my engine but I wish to have clean intake. Oil vapor can lower fuel octane significantly.
You can fabricate one for under 20 dollars.
Nabisco is offline   Reply With Quote
