Old 08-14-2007, 08:11 PM   #1
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Based on my preferred third party non-dealer Toyota service shop...
http://www.japanesebeetle.com/lexusgold.htm
At 15K, you do...
Engine oil, filter & drain Plug crush ring - replace
Engine air filter - cleaning
Cooling system & hoses - visual inspection
External belts - visual inspection of condition
Drive shafts - inspect boots, and re-torque shaft flange bolts
Fuel injection system - add fuel injection cleaner additive to fuel tank: inspect lines, connections & tank vapor vent system hoses;inspect fuel tank gasket condition.
Exhaust system - inspect mounts
Brake components - inspect condition of lines, hoses, master cylinder, calipers & rotors
Brake pads - measurement of remaining pads
Power steering system - check operation & linkages, add fluid if needed, visual inspection for power steering leaks
Undercarriage - visually check for damage and condition, inspect fuel tank bands.
Windshield wiper and washer - fill fluid, clean and inspect wipers
Electrical equipment and lights - check bulbs and operation of warning lights
Suspension - visually inspect ball joints, dust boots, shocks/struts and suspension arm bushings
Battery - load test, top fluid, clean battery terminals
Rotate tires,set tire pressures and check wear and condition of tires
Test Drive
Reset Maintenance light indicator when applicable
Automatic - replace ATF (if equipped) (N/A to WS type fluid transmissions)
Manual transmissions - replace fluid (if equipped)
Rear differential - replace 80W90 gear oil
A/C Filter - clean
Air Filter - clean
aca72 is offline   Reply With Quote
Old 08-15-2007, 03:22 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
At 15K, you do...
Test Drive
A/C Filter - clean
Air Filter - clean
that is WAY off
Trans fluid is recommend to be replace every 30k on AT and MT
change OIL - obviously every 5k
at 15k
I would Check your air filter, it may need changed if you live in a dust area
I would check your brakes as well, depending upon how you drive/stop
Check alignment
Rotate tires-should be free with brake inspection
Old 09-26-2007, 04:05 PM   #3
Trilixia
Trilixia's Avatar
Drives: Black Sand Pearl Liftback
At 15K, you do...
Test Drive
A/C Filter - clean
Air Filter - clean
Price Check?
"That's Corny, Dude!!"
Trilixia is offline   Reply With Quote
Old 09-26-2007, 04:45 PM   #4
aca72
aca72's Avatar
Originally Posted by Trilixia View Post
Price Check?
I haven't done my 15K service yet so I cannot give you an actual amount. In my experience with my Civic, they first give me a written estimate, then they work on the car. When it's time to pay, they explain what they did and deduct certain items that was not necessary. In addition, with some friendly haggling, I get more discounts (been with them for more than three years). Sometimes it pays to know and be friends with your mechanic.
30K throttle service jaggurnaut DIY / Maintenance / Service 39 09-11-2007 08:34 PM
Service in Phoenix Bretsuaz Southwest 4 06-10-2007 07:14 PM
Metro Atlanta Dealer Service Experiences redyaris Southeast 2 03-21-2007 03:59 PM
Do I need to hava a 1000-mile maintenance service?? hans_fh DIY / Maintenance / Service 3 11-24-2006 06:13 AM
Question about service to the yaris foober General Yaris / Vitz Discussion 3 04-25-2006 10:56 PM
