Old 08-14-2007, 11:51 PM   #1
ttufrosty
I too am looking to go to AMsoil 75W-90, I did find these two topics on the Scions. At least they are a starting point on what to do if you need a visual reference.
Changing an Xb
http://s49.photobucket.com/albums/f2...0Oil%20Change/
Changing a tC
http://www.scionlife.com/forums/viewtopic.php?t=120673
ttufrosty is offline   Reply With Quote
Old 08-14-2007, 11:59 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by nsmitchell View Post
It must be the new manual trannys, but in all the manuals I've ever done, I just used a normal motor oil like Mobil-1 10W-30. They all shifted like a dream! 75W-90 is some thick stuff. I wonder why it needs to be so thick?
Don't know what kind of manuals you drove but every manual I know of either takes gear lube (75w-90, 75w-140, etc), or many mazda/ford manual trannys actually take ATF.
Changing an Xb
Changing a tC
I just changed mine to Amsoil as well, after I got my car up on ramps and saw the large fill and drain plugs plainly labled "see owners manual before refilling"... it was a simple job with the beer bong funnel to fill her up...
Old 08-15-2007, 12:39 AM   #3
ttufrosty
Here is another topic from Scionlife with lots of info on changing the manual tranny fluid as well as info on particular gear oil to use.
http://www.scionlife.com/forums/view...n+oil&&start=0
Old 08-15-2007, 06:44 PM   #4
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
Syncromesh Friction Modified sell by GM for manual Corvette transmissions will help having smoother gear shifting after a while
hystria is offline   Reply With Quote
Old 08-24-2007, 09:25 PM   #5
WolfWings
WolfWings's Avatar
3rd-gen Civic manual transmissions specified 30W engine-oil for the transmission, actually. Not 10W-30, 30W. And not gear oil, motor oil. Single-grade motor oil, in a transmission. Still want one of those again.
They also happened to specify that for the engine itself as an option in climates that didn't get below 20F/-7C, so on my '86 Civic I had straight 30W oil in the entire vehicle.
Manual Yaris performance info? SimmZ General Yaris / Vitz Discussion 22 10-27-2009 09:27 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
The Toyota Authorized Repair Manual. LoudYar General Yaris / Vitz Discussion 3 03-29-2007 12:20 AM
2007 LB Yaris - AT - Fluid Change Interval Pavel Olavich DIY / Maintenance / Service 9 03-21-2007 06:09 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
