YRS WHOR
Drives: White 2007 Yaris E-Limited 5dr Join Date: Feb 2007
Simple trick actually..
1. Get a 9V "1N" type battery (the small rectangular general usage ones) and a connector to suit it with flying leads (bare wires). This shouldn't cost more than a few cents at an electronics shop. 2. Unscrew the OEM speaker and disconnect the factory wiring harness from it. 3. Momentarily "tap" the 9V battery leads across the speaker terminals. If the speaker cone moves forward when you do this, the + side of the battery is connected to the + speaker terminal. Likewise of the speaker cone moves backwards, the + of the battery is connected to the - speaker terminal. 4. Use your newfound polarity knowledge to work out which wire on the OEM adaptor is which :) Note: don't use anything more powerful than the battery suggested, and only hold DC current on the speaker as long as you need to (i.e. < 1 second). An old, partially discharged 9V battery is the best bet - a fully charged one will get the cone hopping pretty hard. Lower voltage batteries will also work, but the cone movement may be too small to be useful. |
#2 | |
Audio Junky
| Is worth it to replace only front and rear speakers? | tealio | In Car Entertainment + Electronics (audio / video / alarm) | 35 | 04-16-2010 09:11 PM |
| Call to those who adapted 6.5" speakers to rear of Liftback | W.A.S.P | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 03-10-2009 10:06 PM |
| Installing aftermarket componenet speakers and an amp in a LB | grampi | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 07-06-2007 07:49 AM |
| Component or coaxial speakers? | eflb55 | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 12-11-2006 09:40 PM |
| Matching up right speakers for 4DR Yaris.... ohms match up? | ebowers83 | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 09-13-2006 11:12 PM |
