Old 08-15-2007, 05:20 PM   #1
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
if you don't find the answer here, take out your front springs and put your shocks/wheels/tires back on. then cycle your suspension. that'll tell you what hits first. =) i'm guessing your stock shocks will bottom out before you see any clearance issues.
reznunt is offline   Reply With Quote
Old 08-15-2007, 06:48 PM   #2
jm1681
Janghwa, Hongryeon
jm1681's Avatar
Drives: 20th AE VW GTI
Originally Posted by reznunt View Post
...i'm guessing your stock shocks will bottom out before you see any clearance issues.
Thats good to hear.
I like the car, but it could really stand to be a LOT lower.
Do any typical companies (Eibach, KYB, etc...) make shock and spring setups, or are coilovers the only way to go?
jm1681 is offline   Reply With Quote
Old 08-15-2007, 06:51 PM   #3
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
a quick search would get you an answer to that question
COILOVERS
SPONSORED BY
Old 08-15-2007, 07:42 PM   #4
jm1681
Janghwa, Hongryeon
jm1681's Avatar
No one makes performance shocks for this car?
Sorry, but I don't want to blow a grand on coilovers.
Old 08-15-2007, 08:17 PM   #5
brickhardmeat
Lonesome Cowboy
only TRD struts at the moment
you can pick up a set of coilovers for about 875. shipped or you can spend 200. on springs and 319. on struts
SPONSORED BY
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Lowering Springs - Questions ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-10-2007 08:21 AM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 12:42 PM
FS: Spirit Lowering Springs 1.7" drop xCookiE Items for Sale by private party 2 07-24-2006 08:29 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
