Drives: 2007 Black Yaris Join Date: Aug 2007
Fuel Filter
How often should I change the fuel filter on my 2007 Yaris? Thanks.
Roar?
it is in the fuel pump in the gas tank you would need to drop the whole fuel tank... only needs to be changed if something goes wrong
But won't it eventually get clogged?
![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
yes it will start getting clogged....I was curious to this as well. my last car i changed it every 20000 miles, only because i always noticed a difference everytime i did it, gas mileage went up and easier starts....
sucks its in the fuel tank though....boo
So basically I would have to get a Toyota dealer mechanic to do it, yes?
im not saying that.... its doable.....but its definately not beginner type maintenance item....especially an in tank filter.....
So let me put it this way. Does anyone here regularly change their Yaris fuel filter, and if so, how hard is it? If not, what is the logic behind not changing it? thanks!
A piece of advice that someone would give you if I didn't anyway... do not let your Yaris run down to fumes regularly, if at all if you can help it. Doing that will help extend the life of that fuel filter you're worried about. This is why the manual says do not let the car drop below two bars of fuel.
Is there perhaps an access panel in the trunk to reach the fuel filter like in some cars?
![]() ![]() Drives: 2007 Yaris Liftback Join Date: Sep 2006
Check the Factory Manual, and look in the section on the Fuel system on the pages after FU-24. It involves the removal of the rear seat, pulling out the pump, and then disassembling the pump to get to the fuel filter. The pictures in the manual are pretty self explanatory.
Geez that sounds complicated lol. D*mn you Toyota!
#12 | |
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
____________ Old School Cobble Jockey
Drives: 2007 Yaris LB Join Date: Mar 2007
I don't think you have to drop the tank....just take the back seat out and then it's very easy access. Since the tank doesn't have to be dropped, this maintenence is fairly easy to do.
Additives may well help, but they will not clean a dirty filter.
I agree it won't clean the filter. But a lot of what normally clogs the filter is usually tars that could be reduced in a preventative measure beforehand.
der Zeck
the fiter on our cars does not require changing under normal cercomestances...
thats good to know then. The other benefit to not letting your fuel get low, is that fuel acts as coolant for the fuel pump, pump may get a little warm being constantly on and all the fluid in there keeps it cool....
![]() ![]() Drives: '08 Polar White 3dr Join Date: Jun 2007
Not running down to fumes is good advice for any car. Basically there's little bits of crap that will accumulate over time in your gas tank. These tend to settle at the bottom of your tank (think silt on a riverbed). If you run your tank way low then it tends to stir up the crap that's sitting there at the bottom of your tank and if it is stirred up then it will find it's way into the fuel line where the filter will pick it up.
So one of the keys to keeping a nice clean fuel filter is never to run your car when you're getting down to "E". The rule of thumb that I've alway heard is to never let your tank get below 1/4. So far it has worked well for me. |
| low gas mileage? | yrsdrgn | General Yaris / Vitz Discussion | 30 | 01-17-2019 03:26 AM |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 06:36 PM |
| damaging or no--cabin air filter | roxy84 | DIY / Maintenance / Service | 3 | 06-29-2007 01:17 PM |
| Increased MPG or HP anyone???? | slvryaris | Performance Modifications | 55 | 05-27-2007 10:49 AM |
| fuel filter | ias205 | General Yaris / Vitz Discussion | 15 | 05-14-2007 11:02 AM |
