Old 08-16-2007, 09:14 PM   #1
ChinoCharles
Drives: LB
A piece of advice that someone would give you if I didn't anyway... do not let your Yaris run down to fumes regularly, if at all if you can help it. Doing that will help extend the life of that fuel filter you're worried about. This is why the manual says do not let the car drop below two bars of fuel.
Old 08-17-2007, 12:53 AM   #2
churp
Clean and (dis)Functional
churp's Avatar
+1......plus adding a gas additive occasionally, like seafoam, will help keep the gunk/tars that may build up in the tank and injectors is a good preventative measure. IMO don't mess with the filter unless it needs it.
____________
Old School Cobble Jockey
Old 08-17-2007, 06:21 AM   #3
Pavel Olavich
Drives: 2007 Yaris LB
Additives may well help, but they will not clean a dirty filter.
Pavel Olavich is offline   Reply With Quote
Old 08-17-2007, 01:45 PM   #4
churp
churp's Avatar
I agree it won't clean the filter. But a lot of what normally clogs the filter is usually tars that could be reduced in a preventative measure beforehand.
____________
low gas mileage? yrsdrgn General Yaris / Vitz Discussion 30 01-17-2019 03:26 AM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
damaging or no--cabin air filter roxy84 DIY / Maintenance / Service 3 06-29-2007 01:17 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 10:49 AM
fuel filter ias205 General Yaris / Vitz Discussion 15 05-14-2007 11:02 AM
