Drives: 2007 Yaris LB Join Date: Mar 2007
I don't think you have to drop the tank....just take the back seat out and then it's very easy access. Since the tank doesn't have to be dropped, this maintenence is fairly easy to do.
yes there should be an access panel underneah the rear seat cushion. this is where the fuel pump and level unit is located. not really a big deal to change but if you dont seal it back up prerfectly you will have evap codes to deal with. just make sure you have less than half a tank if your going to do it. besides, i wouldnt worry too much about it unless you have some noticeable fuel pressure or hesitation problems.
07 Yaris LB 5spd AE86 Corolla GTS 5spd http://microimage.ning.com/ http://www.microimageonline.com/store.html |
| low gas mileage? | yrsdrgn | General Yaris / Vitz Discussion | 30 | 01-17-2019 03:26 AM |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 06:36 PM |
| damaging or no--cabin air filter | roxy84 | DIY / Maintenance / Service | 3 | 06-29-2007 01:17 PM |
| Increased MPG or HP anyone???? | slvryaris | Performance Modifications | 55 | 05-27-2007 10:49 AM |
| fuel filter | ias205 | General Yaris / Vitz Discussion | 15 | 05-14-2007 11:02 AM |
