Old 08-17-2007, 06:23 AM   #1
Pavel Olavich
Drives: 2007 Yaris LB
Originally Posted by craigq View Post
Just an FYI: we just had the right front wheel bearing replaced under warranty. It began making a hollow, low-frequency noise/hum at approximately 8000km/5000miles.
The dealership was at first apprehensive about the problem (the "service adivsor" stated that it was normal and that all of the Yarii made a low-frequency hum, without even hearing it himself. I was adamant that the noise was not "normal") but once a mechanic performed a test drive they were quick to diagnose and replace the bearing.
Did you change out the factory wheels/tires before this started to happen?
Pavel Olavich is offline   Reply With Quote
Old 08-17-2007, 07:26 AM   #2
craigq
Drives: '07 Yaris, '12 GLI
It happened with factory 15" wheels/tires.
craigq is offline   Reply With Quote
rattles (front of steering wheel) wushumasterku DIY / Maintenance / Service 37 09-10-2007 11:24 PM
Scion xD Rudeshady Central and South America 1 06-25-2007 01:11 PM
