Old 08-17-2007, 10:24 AM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
The SGII's GPH reading isn't done directly from a flow meter or anything. It is inferred by your RPM, speed, and air flow. This is why you still see ~0.2 GPH when in DFCO... that's the closest the SGII can get according to its internal math as you're still producing high RPM.
Check your PMs for my oil metrics. I don't want to derail this thread.
- Brian
Share the Road
Old 08-17-2007, 12:47 PM   #2
Pavel Olavich
Drives: 2007 Yaris LB
I was under the impression that the GPH value was input to the ScanGauge II via the ODB port, and not calculated by it....I certainly could be wrong however.
Pavel Olavich is offline   Reply With Quote
