Old 08-21-2007, 12:39 AM   #1
ddongbap
Originally Posted by jdium View Post
Some of these post hurt my head. A rev-limiter limits revs, not stupidity... Do you run your car into walls because it has airbags? Do you risk sex with an infected person because you have condoms? It's a LIMITER, not a shift light...
Way to go Corky...
You're missing the point.
I'm saying, why have a rev limiter where its at, when running into it will void warrenty? Why dosen't Toyota just set the rev limit low, so when you hit it nothing will happen? Or why have it at all? If there is a recorder that'll void your warrenty, that'll have the same effect if your engine blows up. You'll be left shit out of luck.
The air bag anology isn't the same as the rev limiter. Hitting the rev limiter dosen't require a wall. Why the hell would an engine create all of its power so close to the rev-limiter? How would you gain all of the 8.whater (or whatever the 0-60 speed is) by not reving to where the power is? Everyone should create big bore, big stroke engines, so going near the rev-limiter would be worthless. Not to mention the non s models do not have a tach, so figureing out where you're at isn't easy for the new driver..
My X-Runner dosen't have much top end power. Well, it does, but I've got oodles of torque in the low end, so I wouldn't really have to rev so high. Wouldn't that be the solution to a rev-limit warrenty void?
If you think that hitting a simple rev limiter is SUCH a risk, to be compared to condoms, and air bags, then you really need to get some of your values straight.
... and that picture wasn't called for.
ddongbap is offline
Old 08-21-2007, 06:32 AM   #2
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
I'm missing the point? My point is that there is NO reason to be that close to the rev limiter. Unless my Yaris is different than your Yaris, there is a definite
drop-off-point in power as the revs top out, so shift there. There is never a reason to be buzzing the rev-limiter for extended periods. Like I said, it's a rev-limiter, not a stupidity limiter...
The engine develops all of it's power at high revs because that is how it is designed. Again, when you feel the drop in power, shift. The max shift point does not change from day to day, try to remember about what it feels like, and SHIFT! If the Yaris made it's power low in the revs, it wouldn't get close to the same gas mileage, which is the basic point of the car.
What the hell is the "8.whater"?
If a manufacturer warranty's your product against defects, shouldn't they be able to monitor it for defects. That is what this "rev-limiter recorder" does, it monitors defects in the DRIVER. Why should the manufacturer be responsible for your abuse?
As for my values, I'm thinking mine sound pretty good. I don't do stupid stuff just because I have safety equipment...
...and the picture was funny
...and this will be locked soon, that's what happens when I get more than 1 post in a thread
It's scary to think that half the people surrounding you are below average...
jdium is offline
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 07:17 PM
service engine light @ 9000 mi? dandj DIY / Maintenance / Service 21 01-03-2007 12:30 AM
High compression engine flow-vitz General Yaris / Vitz Discussion 1 11-15-2006 01:03 PM
Check out my new light ( SEDAN )) mariosuper Cosmetic Modifications (Exterior/Interior) 5 09-22-2006 09:06 AM
