Old 08-21-2007, 12:19 PM   #1
AlphaFox
AlphaFox's Avatar
Drives: 07' Yaris Liftback - silver
who said anything about driving at redline for days on end?
I was racing someone, and was at a point where if I shifted I would be making less power than if I kept it at 6K, so I did that. then the light blinked.
since I have installed a weapon R intake I have not seen the light return.
AlphaFox is offline
Old 08-21-2007, 01:37 PM   #2
Pavel Olavich
Drives: 2007 Yaris LB
I think the power band maximizes WAY before 6,000 RPM....it is stupid to shift at start of red line...better to determine where the power is maximum, then shift just after that point.
And dudes, don't feel scared of near redline RPM's....at that point the engine does not wear out any faster then at mid level RPM's....as to engine wear, 90% of that happens during morning starts, and up to 10 minutes after the engine is running....oil needs time to get to operational temperature...too thick, it does not flow as well...and it is engine flow (more then oil pressure) that protects the engine the most.
Pavel Olavich is offline
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 07:17 PM
service engine light @ 9000 mi? dandj DIY / Maintenance / Service 21 01-03-2007 12:30 AM
High compression engine flow-vitz General Yaris / Vitz Discussion 1 11-15-2006 01:03 PM
Check out my new light ( SEDAN )) mariosuper Cosmetic Modifications (Exterior/Interior) 5 09-22-2006 09:06 AM
