Old 09-01-2007, 11:42 AM   #9
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
Originally Posted by CF-Shane View Post
Take the Yaris for example: I see a solid beam rear axle with coil springs, and Toyota's marketing department sees a "tortion beam rear suspension".
There's a difference. The Yaris' "solid beam rear" actually appears to be under torsional load from what I saw, looking at it after I had my TRD rear sway bar installed. The fact that the 'solid beam' is a near-duplicate of the rear sway bar but attaches to mounts more-or-less one-bolt-higher than the sway-bar shows it actually is a torsion beam, not a true 'dead axle' design. The fact that there is no mount for a track rod/panhard rod (Suspension SP-62) shows that (at a minimum) the rear suspension is a twist-axle rear, which means that, yes, the rear beam is designed to be under torsional forces like a torsion-bar setup.
The only difference between a 'twist axle' rear and a 'true' torsion-beam rear is if the rear axle is two parallel (at rest) rods cross-linked or one single rod. The two parallel rods gain a minor design-engineering-simplicity advantage at a moderate complexity disadvantage. The single-beam is, in effect, two half-length torsion bars linked at the mid-point by comparison, and more math and proper design can let it perform almost well as the two-rod setup AFAIK, though it doesn't add as much chassic-rigidity as the two-bar setup. This is (I believe) why a rear sway bar is so noticable on the Yaris.
WolfWings is offline   Reply With Quote
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 03:06 PM
