Old 09-11-2007, 01:30 PM   #1
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
Now that the rust has begun, I think it may have trouble adhering properly. I suppose if you scuff all the rust off (wire brush in a drill) you could make it work ok. Also, stove paint tends to come off, like the dust primer leaves, so try not to get it everywhere
Zero to Sixty in just fifteen minutes...
YarisTom73 is offline   Reply With Quote
Old 09-11-2007, 01:50 PM   #2
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
^ Even paint cleaner would work if you want to apply the time.
Old 09-11-2007, 02:19 PM   #3
dadi_oh
dadi_oh's Avatar
Drives: RS 4 Door Hatch
I have some stuff called "rust converter" that chemically reacts with teh rust to create a paintable substance (or so it claims). I will probably wire brush off the area of interest, clean it up the best I can with some sort of solvent (maybe IPA), apply the rust converter, mask off the surrounding areas, and paint. I have just never heard of painting a muffler before so wanted to see if anyone had tried it before.
06 RS 4 Door Hatch - Black
dadi_oh is offline   Reply With Quote
Old 09-11-2007, 02:22 PM   #4
staticorex
staticorex's Avatar
There was some talk of it when Chris sprayed the inside of the wheel wells. You could search for that to see if any good info was brought up. Can't remember the title though, sorry.
Old 07-03-2009, 08:45 PM   #5
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
you need something like this or your need to sand blast it, its the only way you can really get rid of the rust.
if you just paint over it i'll flak off in a day or 2
http://www.4055design.com
stock muffler interesting concept unbeknown to owners... marcus Performance Modifications 7 08-16-2007 06:12 PM
What is the Most Quiet aftermarket performance muffler thomasward00 Performance Modifications 18 08-03-2007 04:57 PM
F5 fujita air intake + megan muffler westyaris2 Performance Modifications 4 07-17-2007 07:27 PM
Muffler Tip ~ Good Idea? jaspie Cosmetic Modifications (Exterior/Interior) 14 01-17-2007 07:34 PM
CAI and Sports Muffler littlecarlove Performance Modifications 18 11-04-2006 11:18 PM
