Old 09-11-2007, 08:34 PM   #1
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
Originally Posted by socko View Post
you'll get lots of white smoke but if you drive the car 10 or so miles (running the RPM's up to about 4000 it will quickly burn off).
be careful with that fuel injector stuff guys, it heats the living crap out of your catalytic converter. its best to let it idle out for a while before you take off and hit high rpm. could set a misire code too (misfires are what overheats and kills your catalyic converter)
also our hydraulic clutch takes dot3 brake fluid. the clutch master cylinder works similarly to the brake master clyinder, thus same fluid.
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
Service in Phoenix Bretsuaz Southwest 4 06-10-2007 07:14 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
Metro Atlanta Dealer Service Experiences redyaris Southeast 2 03-21-2007 03:59 PM
Do I need to hava a 1000-mile maintenance service?? hans_fh DIY / Maintenance / Service 3 11-24-2006 06:13 AM
