#27 |
Most of this info has been posted before (#73, 78, 84)) and in a few other threads, but for those of you who missed some of it...
As I understand the situation, Toyota did not include the A/C filter because the filter frame will not fit due to the position of the blower. Toyota believed that if the filter frame could not fit, then the filter could not be installed properly. The frame and filter are an assembly unit. So, they just left it out! It's that simple as far as Toyota was concerned. Unfortunately, the owners manual refers to the A/C cabin filter probably because it should definitely be standard equipment and it was assumed it would be... only later to discover the filter frame wouldn't fit. More unfortunately, the dealers know absolutely nothing about this situation and are totally in the dark when confronted with it. Seems to be a breakdown in communication at several levels. I only discovered that the car had no filter when something from my glove box got sucked into the blower and began making all kinds of noise. Other yarisworld members have had the same experience. Indeed, it is a problem! Thankfully, we at yarisworld have found that a filter will in fact fit (with a bit of gentle massaging) and function quite well without the filter frame. It's a quick, easy, and inexpensive install. At this point, we've learned that a Purolator filter #C38188 and Bosch filter #P3750 will fit adequately right out of the box. So now the qustion has risen once again... what will Toyota and/or the dealer do about all this? |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 06:36 PM |
