#19 |
Bathroom + Laptop = <3
YUP! well, I'll be buying another pedal assembly to try this out on unless anyone can confirm otherwise, because i am pretty sure this will work on any other dbw models because it is the same standard...
http://www.mustangforums.com/m_37925..._1/key_/tm.htm If anyone is in the process of being down there or taking theirs apart would be cool to check this out... ill actually make another post when im done doing this mod as well... |
#20 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
new engine
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
#21 | |
#22 | |
#23 |
i thought it should be similar but sadly its a thing of magnetics and electronics -_-
#24 |
i think it's really simple... there ARE quite a few oem ECU made for the 1nz-fe with a wired throttle body.
#25 |
didn't know that many cars came with the 1nz-fe, but i confirmed that the echo throttle body and assmebly will work....but what about the ecu?
edit: damn Applications: Toyota Yaris/Echo Scion xA/ist Scion xB Toyota Vios Toyota Raum Toyota Porte Toyota Platz Toyota Auris Toyota Fun Cargo Toyota Premio Toyota Allion Toyota Sienta Toyota WiLL Toyota Probox Toyota Ractis Toyota Corolla Axio Toyota Corolla Fielder |
#26 |
i'm taking a guess you can use the ecu from a scion xA??
BUT.. i'm pretty sure you will have to redo the whole wiring harness anyways... |
#27 | |
I don't think so... I think they use different coding as like ones 32 bit and one isnt in some maps... but I'll have to check it out... see if they have one at a junkyard... I'm aiming to find an Echo and grab the pedal assmebly and throttle body with cable from there. that would probably be the easiest car to find there...
edit* Quote:
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Tree 1 - Yaris 0 | gabagooo | General Yaris / Vitz Discussion | 19 | 04-25-2007 05:24 PM |
