Old 11-02-2010, 01:25 PM   #1
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
lol..even new car can grind on reverse..you have to know a trick.. all you need to do is slap it on any forward gears before reverse..i use first or second gear then reverse and youll be grindless fro life unless ur synchro goes.
Wow, did not know this. Sounds like a great tip!
Old 07-17-2011, 02:05 PM   #2
maximapitko
Drives: Nautical Blue Yaris Sedan 5spd
Originally Posted by yaris2010RS View Post
this is gonna seem like a stupid question but im thinking of changing my tranny oil..... its a 2010 and it only has 31,xxx km on it..... im jsut sick of the the grinding into reverse and i do drive fairly hard and feel a better quality oil would benifit. what do u think? is it worth it? i was thinking either royal purple or redline.
reverse gear does not have a synchro. This is pretty common on cheaper cars.
I changed the gear lube in my 07 sedan at 100k with mt90. The original fluid looked as good as new...
maximapitko is offline   Reply With Quote
Old 11-02-2010, 07:44 AM   #3
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
Id go for the Redline MT 90.
soloecho2 is offline   Reply With Quote
Old 11-02-2010, 10:50 AM   #4
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Will do this soon, does anyone have the pics saved ( or is it just my computer that they don't show).
Second question is where to get Redline?
Old 11-02-2010, 11:43 AM   #5
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
i'm on Royal Purple now, and my gears still grind somehow, reverse still stuck on cold morning, first gear still stiff, maybe Redline next time and compare.
jamal1984 is offline   Reply With Quote
Old 11-02-2010, 02:54 PM   #6
yaris2010RS
yaris2010RS's Avatar
inside the engine bay on ur tranny check ur linkages and grease/oil where felt needed. my 5th and reverse were stiff and toyota did this for me now all gears go with with ease
Old 11-28-2010, 04:23 PM   #7
jmjonesey
jmjonesey's Avatar
Drives: Red 2007 Yaris Sedan
Send a message via AIM to jmjonesey
Just wanted to say thanks OP for posting this, I am doing a ton of 60k maintenance on my car, new plugs, new brake pads, and now thanks to you i have new tranny oil :-) much obliged!
jmjonesey is offline   Reply With Quote
Old 02-26-2011, 01:20 PM   #8
Irish
Drives: 2007 Yaris Sedan
Another thanks to the OP for this very helpful thread. I just passed 100,000 miles on my '07 and even though the dealer said that the transmission oil didn't need to be changed, I went ahead and bought some MT-90 from amazon.com and changed it today in addition to the coolant. Many thanks for this forum.
Irish is offline   Reply With Quote
Old 11-02-2010, 12:23 PM   #9
Hershey
ROYAL PURPLE likely to be a GL-5 which is the same as the factory fill which causes the grinding and clunking into reverse . You'd want a GL-4 , like that of REDLINE MT-90 . Does make a big difference . Better shifting on cold days with MT-90 . Changing the gear oil is easier than a oil change . After the fill of the GL-4 , work through all the gears ( reverse too ) and before you know it shifting is a breeze .
Old 11-02-2010, 01:18 PM   #10
Shinare
Shinare's Avatar
I called around, found a place local that will sell the redline MT-90 for $9.95 per qt. Going to do this this weekend. I've noticed since I got the car that reverse is pretty chunky if not a little grindy at times. Will try this. No problems with any of the other gears.
Going to have to buy a few things first. I've never seen a funnel like pictured in the DIY. I'm going to have to get something similar to put it in that side plug. I also don't have a torque wrench. A friend of mine that I work with who also works on motorcycles says 29 ft-lbs of torque is not very much. Just a slight muscle flex as your tightening it after its all the way on. (course he's a pretty big guy so that's relative) Should I buy a torque wrench just for this? Is the torque that important? I also will need to get some kind of pan to drain it into. Do i just take the used oil to wal mart or somewhere? It's probably a good idea to buy something to transport the old oil in rather than in the open pan in the back seat, heh. Goodness, this is adding up.
Old 11-02-2010, 01:35 PM   #11
Hershey
Do this if you don't have a torque wrench . Take a medium to fine SHARPIE permanent magic marker with black ink and draw a line on the drain fill plugs and the tranny itself so they line up . Then write D.P. ( drain plug ) or F.P. ( filler plug ) on the plug so when you put them back in you'll be using the same plug so they will line up . Can tighten it just a bit more beyond the mark on the tranny , if needed .
Old 07-14-2011, 08:05 AM   #12
bronsin
bronsin's Avatar
Hmm interesting thing to do. But would it work if you changed the sealing washer? (also unecessary)
Torque wrench complete overkill for something like this however. Manual says something like "Torque the oil filter with a torque wrench. If you dont have one take it to your dealer for proper torque."
Just intimidating the public Im afraid. The bastards. Actually torqueing the OF to their spec will prolly result in it being nearly impossible to remove IME.
Old 10-02-2011, 12:50 AM   #13
Hershey
This method worked for the '08 YARIS 3 door w/ 5 speed manual . The permanent marker remained for a while . If I remember correctly , reused the washer from the factory . Would get a new one when doing a second change of gear oil .
Old 05-18-2012, 01:41 AM   #14
kyote
kyote's Avatar
Drives: 2007 liftback base
i didn't notice this thread until I already did the job, and apparently I over-torqued the nuts. i was assuming they were crush washers like on my honda. is this a problem?
also, my oil was very dirty at 26k.
kyote is offline   Reply With Quote
Old 11-02-2010, 01:49 PM   #15
Shinare
Shinare's Avatar
Went out to take the pic for my avatar just now and drove to a different parking place in the sun. I went from driving around in first to putting it into reverse to back into the parking place. Slight grind in the gear as I placed it into reverse. *shrug* hopefully the gear oil change will help.
Old 03-16-2011, 12:01 AM   #16
JDfan33
Drives: 2007 Yaris
Great thread and thx for the great pic's
JDfan33 is offline   Reply With Quote
Old 04-06-2011, 09:05 PM   #17
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
I just changed my trans fluid today at 55,400 miles, Tranny fluid looked as good as new when coming out. No metal flake look to it. Installed 75w-90 Royal Purple and went for a drive. Well don't waste your 30 bucks on this oil. My car did shift better. On cold days before it would be stiff or hard to get into gear down shifting to second and to first. It is better, but not as good as I was hoping. In 5,000 miles when I change my oil I will be going to MT-90 and will update you guys on how that performs.
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 04-07-2011, 01:56 AM   #18
Hershey
Big difference , when cold shifting and no clunking into reverse . After the change , take it out for a spin and work through all the gears , including reverse . Not long after you'll be in for a smooth transition .
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 02:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
