the yaris uses ground switching.
so you can tap it to ANY source of +12v and switch it the way you want. tap it to the cig lighter if you want, and switch it with the dome light switch. you know what i mean? the +12v is constant anywhere.. so it will work as long as the fuse is big enough. now i can't answer you for the fade in fade out. |
| Put cold cathodes in a liftback | ChinoCharles | Cosmetic Modifications (Exterior/Interior) | 27 | 05-03-2009 05:03 AM |
| Wiring Cathode to dome lights? | Nexus1155 | DIY / Maintenance / Service | 3 | 09-11-2007 04:10 PM |
