Old 09-18-2007, 11:47 AM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
You'll need spring compressors to remove the front springs from the strut but not to install the new springs into the strut, at least not with Tanabe springs. I suppose you could remove the front springs without a compressor but be careful, a spring under load can be a dangerous thing.
Just rent them from an Autozone or Checker Auto. You get all your money back if you return them in 2 days. Free rental...
PetersRedYaris is offline   Reply With Quote
Old 09-18-2007, 02:24 PM   #2
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Well, I'm installing coilovers, so I don't need to take the springs off the struts. However, I believethe Megans requre you to use some parts from the OE shocks.
I've rented spring compressors many times; they're just a PITA!
Old 09-18-2007, 02:29 PM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
You do not need spring compressors to remove the stock springs, or install lowering springs. There is little to no tension on them, they pop about 3 inches. The coilovers probably require you to use the top hat on the front struts, so the front springs need to be removed from the struts.
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
n00b suspension install question The Stig DIY / Maintenance / Service 25 07-12-2007 08:58 AM
Tanabe NF210 spring install help Jerkratt Performance Modifications 8 06-08-2007 10:13 AM
NorCal: Suspension install The Stig California 12 06-05-2007 12:51 AM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 08:32 PM
