Old 09-18-2007, 03:19 PM   #1
Joker
Generally 4 into 1 headers are designed for gains in the higher rpm range (5000+) which also generally means you lose your bottom end. As most people on this board know that normally aspirated cars will benefit from intake/exhaust/header mods but carefully choosing these parts is the key. I also know that only about 2-3 people on the board actually put their car on a dyno. I would be curious what gains if any this header provides under 5000 rpm vs. the stocker. Not everyone tools around at 5 grand plus all the time. Just my 2 cents....
Joker is offline   Reply With Quote
Old 09-18-2007, 03:28 PM   #2
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
I think you make a good point, particularly considering the VVTi takes over at higher RPM and thus the bottom end is already the weaker end of the spectrum when it comes to our Yaris' powerband. So, if there is even the most remote chance that this or any header could reduce bottom end power, count me out . There's two more cents
Zero to Sixty in just fifteen minutes...
YarisTom73 is offline   Reply With Quote
Old 09-20-2007, 11:06 AM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I'm not going to waste the money to dyno the car, but there is a noticable power increase BELOW 5000 RPM. The car even takes off from a stoplight easier. The bottom to mid range gain was more dramatic than the top end gain.
Keep in mind, all I have done to the car is the header and a light crank pulley.
****PICS ADDED TO ORIGINAL POST****
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Are We Still Stuck With the 4-1 Headers? Sabretooth Performance Modifications 31 02-20-2009 08:57 PM
OBX Header Galavoxx Performance Modifications 3 04-20-2007 11:36 AM
Megan Header Advice jamal1984 Cosmetic Modifications (Exterior/Interior) 1 02-20-2007 07:22 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
