Old 09-19-2007, 04:00 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
The catalytic converter serves many valuable purposes, but mainly the severe reduction of noxious emissions. Not only does this greatly help the environment but it is also mandated by Federal law.
To remove it is one of the most irresponsible and selfish things an automobile owner can do, and it is my sincere hope that anyone that does so gets caught and punished for it.
- Brian
Share the Road
BailOut is offline
Old 09-19-2007, 04:05 PM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
...To remove it is one of the most irresponsible and selfish things an automobile owner can do, and it is my sincere hope that anyone that does so gets caught and punished for it.
PetersRedYaris is offline
Old 09-19-2007, 04:08 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
On my turbo lebaron I upgraded to a 3" exhaust and kept the cat. You can get performance cats that filter out the emissions their supposed to while providing high-flow. I purchased one for cheap on ebay from a seller that sold catco brand. Worked great. There is NO testing where I live, but I wanted to keep it legit.
Astroman is offline
Old 09-19-2007, 10:33 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by Nexus1155 View Post
Just wondering what everyone thinks of cutting out the cats and running straight pipes. Will it add more power, because of it being more free flowing(I know its not a turbo vehicle but hey). Will it sound nicer or more annoying, does anyone have any vids or sound clips. Any comment is appreciated...
I don't have to worry about inspection or anything and global warming is BS so please no tree hugging splurs... It's not that I don't care about the environment I yell at people for littering.
Originally Posted by PetersRedYaris View Post
Yes, that ment your two morons.... obviously he does not care your opinion.
I was going to wait to go catless, but just because of that comment from Brian/BailOut, I am getting them bitches cut out and throwin another resinator in. I wish I lived near him, I would blow those noxious emissions right on his door step.
Black Yaris is offline
Old 09-19-2007, 11:12 PM   #5
umm_bacon
Medium Pimpin
umm_bacon's Avatar
Drives: 07 Gerbil Powered Hatchback
Emissions Nazi!
umm_bacon is offline
Old 09-19-2007, 11:14 PM   #6
alhope34
Spool'd
Drives: 07 yaris, 16 gen coupe rspec
Haha, I like your response.
alhope34 is offline
Old 09-19-2007, 04:08 PM   #7
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
This is true also
It's a Vitz!
Vic-2NZFE is offline
Old 09-19-2007, 10:12 PM   #8
alhope34
Spool'd
A lot of people around here with loud mufflers on their civics get their exhaust shops to cut a hole at the top of the cat and hollow it out then wield the top back on so from underneath unless you look really close, it looks normal. But really inside it's just a straight pipe through the cat's outer shell.
In Ontario we have really strict emissions testing, but it isn't too hard to get emissions faked. When I got my first car I didn't know it was so badly beat up as it was, and I was told by a few mechanics the best and easiest solution to solve the emissions problem was to get a new car, which I couldn't do. When I ran out of temp plates the DMV would give me, I finally had to get the papers done. Still had the car 4 months after that till it totally died. I even replaced the cat on that car and ALL of the o2 and no2 sensors on the exhaust...still didn't fix the emissions. Kept failing on what the place called "nox". Limit was 200 and something and my car was doing in the 2500's
alhope34 is offline
Old 09-19-2007, 10:30 PM   #9
BailOut
BailOut's Avatar
"Nox" is short for "noxious emissions". Gasoline-burning vehicles produce 3 kinds of emissions:
1) GHG (greenhouse gases - Carbon Dioxide and Nitrous Oxide)
2) Nox (noxious emissions - Nitrogen Oxide, Carbon Monoxide, Sulfur Dioxide, various carcinogenic (cancer-causing) hydrocarbons... all the stuff that acid rain is made of)
3) Passive (paint flakes and fumes, leaking fluids, etc.)
A catalytic converter helps mostly with the "nox" group.
- Brian
Share the Road
BailOut is offline
Old 09-19-2007, 11:08 PM   #10
alhope34
Spool'd
My car failed harder with the new cat. And I even drove it 500km before I got it re-tested. got 1000 or so with the old cat that was all clogged. And yes, the new cat was also a three-way. I know two way cats don't work as wekk
alhope34 is offline
Old 09-20-2007, 01:44 AM   #11
WolfWings
WolfWings's Avatar
Smile
No, incorrect, wrong, wrong, wrong. As wrong as claiming Annie Lennox wrote a song about walking on propane gas.
nox stands for a single chemical family being tested for: Nitrous OXides.
Petrol-based engine emissions-testing systems aren't even remotely categorized like you listed. The 'bad chemicals' they produce are:
  • Nitrous OXides (two Nitrogen atoms and a random number of Oxygen atoms)
  • Carbon Monoxide (two Carbon, one Oxygon)
  • Unburnt HydroCarbons (one Hydrogen, one Carbon) actually.
These (NOX, CO, HC) are what are tested for in a tailpipe test, also. A three-way cat converts NOX better if you're running a rich mixture, or converts the other two better if you're running a lean mixture. Basic chemistry, replace a cat, adjust the fuel mixture and you can pass an emissions test almost always. California is so hard to pass because of their inspections, which include the most common ways to adjust the fuel-mixture having to be factory-spec.
At least research your claim a little before spouting it off like it's gospel, 'kay?
WolfWings is offline
Old 09-20-2007, 01:54 AM   #12
BailOut
BailOut's Avatar
Either I was misinformed at the testing station I asked lot of questions at, or Wikipedia is wrong. Either scenario is highly possible.
The end result is the same regardless, though:
Catalytic converter == good, hence why it is mandatory in most parts of the developed world.
No catalytic converter == acid rain, contaminated water, etc.
- Brian
Share the Road
BailOut is offline
Old 09-20-2007, 09:57 PM   #13
WolfWings
WolfWings's Avatar
Nah, I'll disagree with you.
Low emissions == good, yes. But catalytic converters are just the easy way to 'force' all emissions down quickly, ergo why they were made basically manditory.
The Honda Civic was created initially to avoid having to add a catalytic converter (CVVC was the original engine-tech nickname, ergo the series-name CiViC) for example, and I've run vehicles with the Cat removed that still passed the tailpipe-sniff test just fine as long as they were well-tuned and well-maintained.
Old 09-20-2007, 01:38 PM   #14
AlphaFox
AlphaFox's Avatar
Drives: 07' Yaris Liftback - silver
I dont get it. obviously you people know he knew the environmental effects of it and doesnt care, he is just wondering performance benifits. WHY are you all blabbing about the NOX and crap that might come out of the exhaust, he doesnt CARE and spescifically stated NOT to post things like this. why post in a thread if the author of it says he doesnt care about that..??
that said, I a agree not running a cat is kind of dumb, for one it REEKS if your driving behind someone and they arent running a cat.
AlphaFox is offline
