Old 09-20-2007, 01:44 AM   #1
WolfWings
WolfWings's Avatar
Smile
"Nox" is short for "noxious emissions". Gasoline-burning vehicles produce 3 kinds of emissions:
No, incorrect, wrong, wrong, wrong. As wrong as claiming Annie Lennox wrote a song about walking on propane gas.
nox stands for a single chemical family being tested for: Nitrous OXides.
Petrol-based engine emissions-testing systems aren't even remotely categorized like you listed. The 'bad chemicals' they produce are:
  • Nitrous OXides (two Nitrogen atoms and a random number of Oxygen atoms)
  • Carbon Monoxide (two Carbon, one Oxygon)
  • Unburnt HydroCarbons (one Hydrogen, one Carbon) actually.
These (NOX, CO, HC) are what are tested for in a tailpipe test, also. A three-way cat converts NOX better if you're running a rich mixture, or converts the other two better if you're running a lean mixture. Basic chemistry, replace a cat, adjust the fuel mixture and you can pass an emissions test almost always. California is so hard to pass because of their inspections, which include the most common ways to adjust the fuel-mixture having to be factory-spec.
At least research your claim a little before spouting it off like it's gospel, 'kay?
WolfWings is offline
Old 09-20-2007, 01:54 AM   #2
BailOut
Steals terrorist's lunch
BailOut's Avatar
Either I was misinformed at the testing station I asked lot of questions at, or Wikipedia is wrong. Either scenario is highly possible.
The end result is the same regardless, though:
Catalytic converter == good, hence why it is mandatory in most parts of the developed world.
No catalytic converter == acid rain, contaminated water, etc.
- Brian
Share the Road
BailOut is offline
Old 09-20-2007, 09:57 PM   #3
WolfWings
WolfWings's Avatar
Nah, I'll disagree with you.
Low emissions == good, yes. But catalytic converters are just the easy way to 'force' all emissions down quickly, ergo why they were made basically manditory.
The Honda Civic was created initially to avoid having to add a catalytic converter (CVVC was the original engine-tech nickname, ergo the series-name CiViC) for example, and I've run vehicles with the Cat removed that still passed the tailpipe-sniff test just fine as long as they were well-tuned and well-maintained.
