Que espirales me recomiendan !!!
TEngo un yaris del 2004-2005 sedan.
Les tengo unos rines 17 y llantas 215-45-17 ( pronto las voy a cambiar por unas 205-40-17, porque me estan rosando las llantas de adelante por dentro cuando corto todo el timon). La pregunta es la siguiente, que espirales me recomienda, que le hayan funcionado bien. Que no tengan ningun tipo de molestia, que quede bien puesto y se vea bien. Investigue sobre los TEIN S.TECH Spring is an excellent step towards suspension tuning. They offer approximately a 1.5 inch drop for a more aggressive appearance. Comes with a 1 year limited warranty. Spring length is guaranteed not to sag more than 5mm and to be clear of any manufacture defects (see limited warranty for more details). * One year limited warranty. * High-grade material adapted to improve guaranteed satisfaction. * Rubber spring protector sheet to prevent noise (most applications). Drop Height F/R: 1.9/1.9 The Tein S-Tech spring increased performance is attained by variance of spring rate and coil design. Driver’s will experience a feeling of increased control, more stability and reduced body roll during cornering. All Tein S.Tech springs are developed to be used in conjunction with OEM or OEM replacement shocks. Each Tein S.Tech Spring is road tested in the US for proper balance between performance and comfort. The line is produced with vanadium (SAE9254V), which is durable lightweight and has properties to retain more spring stroke. Tein S-Tech Spring length is guaranteed not to sag more than 5mm and to be clear of any manufacture defects (see limited warranty for more details). |
#2 | |
Abdiel Hiram |
![]() ![]() ![]() Drives: Yaris Sedan 2005 Motor 1NZFE Join Date: Jun 2006
Bueno yo uso las TEIN H.TECH que solo bajan 0.9".
Para mi, TEIN es lo mejor. si puedes invertir en un coilover TEIN mucho mejor...
Yaris/echo 1NZFE NCP12 -> TEIN High-TECH spring, Tower bar Generic, HOTCHKIS Sway bar -> TRD Performance air filter, Stage 1 Gripforce F1 clutch |
Qu tan anchos son tu rines?
![]() It's a Vitz! |
tein o h&r o eibach
Super Yaris Panamá 05 HB - 2NZFE 1.3L Engine - 068 Super White - Aem CAI - Trd Oil Cap - Rev 17" rims -Toyo 205/40/17 wheels - Vibrant Front Strut Bar - Tein-S springs - KYB Gas Shocks - Header DC-S 4-1- Tenzo-r steering wheel- Pioneer Avh-P 5750 |
Ademas tema discutido como 4 veces!!
favor buscar y leer en el foro saludos. http://www.yarisworld.com/forums/showthread.php?t=7809
Los rines son TSW, pero creo que son 7.5 porque se ven bien anchos, ademas los compre de segunda y los mande a pintar de inmediato,, no me fije del ancho del rin
detras de los rines siempre dice las dimensiones (ancho) y ademas el offset del rin (ET 40, ET 45, etc)
| Fer.pa patio sale!!! | Fer.pa | Central and South America | 7 | 09-24-2007 10:36 PM |
| Tein S-tech for Xb 04+ on Yaris Hb 2005 | Fer.pa | Central and South America | 18 | 08-04-2007 10:59 PM |
